Old 09-27-2018, 09:25 AM   #1
2019 28' Flying Cloud
Las Vegas , Nevada
Bought a Hensley
I looked at all the others and bought a factory reconditioned Hensley. Factors:
- Zero Sway by design. Should let me put a 300lb MC on a rail off of the rear bumper as well.
- No heavy hitch and greasy spring bars to lug around.
- Great tech support and responsiveness.
- Made in the USA
Price = $2360 delivered and includes spare parts kit.
OutbackUSA is offline   Reply With Quote
Old 09-27-2018, 09:47 AM   #2
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Good selection on the hitch. Be diligent on the install and patient on the learning curve to hook it up - you will love this hitch!
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 09-27-2018, 10:22 AM   #3
"Cloudsplitter"
Welcome Aboard!! 👍
X2
An 'O' ring on a Hitch'n stick will help hook-up a lot.
Sweet Streams...👍
ID:	323828   Click image for larger version
Old 09-27-2018, 01:14 PM   #4
Sag Harbor , New York
Originally Posted by OutbackUSA View Post
. . . Should let me put a 300lb MC on a rail off of the rear bumper as well.
Which would probably exceed Airstream’s design parameters, which limit a rear bike rack to the Fiamma plus 70 lbs. of bike weight.
Welcome to the forum.
Peter
Old 09-27-2018, 04:09 PM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
A 300lbs Motorcycle on the back of your Airstream will be DEATH the the rear frame. There is not enough metal back there to support that much weight bouncing around back there.
Old 09-27-2018, 04:24 PM   #6
300 pounds plus the weight of the hitch and "rail," all cantilevered much further away from the rear axles, than is the Fiamma bike rack, which is tucked in nice and tight above the rear bumper.
Old 09-27-2018, 04:28 PM   #7
"Cloudsplitter"
Peter
WOW...missed that one!!!
No MC hanging off the rear...frame not designed for it.
Old 09-27-2018, 05:17 PM   #8
Retired.
. , At Large
Keep the Hensley.
Lose the motorcycle.
Old 09-27-2018, 05:46 PM   #9
2007 22' International CCD
More precisely, the Hensley, or any other anti-sway system will NOT be able to control the sway of 300 pounds of motorcycle hanging a foot or two behind the rear bumper. It would take too much weight off the hitch ball as well.
Ditto on the Airstream's frame not being built to take that much weight in the rear. The Airstream's frame is not built like a conventional trailer's frame is. It is designed to be held up by the shell of the trailer, and be just strong enough to take the load of the contents of the trailer. Adding weight past the rear bumper will induce uncontrollable sway, damage the frame to the point of breaking it, and most likely will damage or break components of the hitch as well.
If you must carry a motorcycle, put it safely in the back of the tow vehicle. Trying to hang it on the back of the Airstream itself will potentially and quickly lead to an out-of-control sway condition and loss of the whole rig.
Not a safe ride by any means, and this situation will surely scuff your motorcycle at the minimum...
Old 09-27-2018, 05:59 PM   #10
white laker's Avatar
2008 34' Classic S/O
Arnprior , Ontario
Welcome to the Henley Experiance!
as said..... M.C. hanging on the rear of your A.S.(s) is a no no!
Try hooking up a few times before you head out. Do it a few times and then a few times more. Its easy once you nail it. If you have a rear view camera on your T.V. use it. If not... get one! Put a small piece of reflective tape over the hutch box to guide the 'stinger' into place. The learning curve is well worth the end result. Safe towing!
Pete
Pete Crook
"Put it all behind you!"
S/OS#88
white laker is offline   Reply With Quote
Old 09-27-2018, 08:05 PM   #11
2017 28' International
Jim Falls , Wisconsin
I think I would buy a front hitch and load it on the front of the vehicle if the payload of the TV is adequate. I’ve seen that done. But not on the back of the AS. I have a propride and wouldn’t think of doing that. I have a front hitch that’s rated to 500lbs. Makes more sense.
Daquenzer is offline   Reply With Quote
Old 09-28-2018, 06:53 AM   #12
Las Vegas , Nevada
I have a backup cam. So far so good, with the temp, standard hitch I have used.
Old 09-28-2018, 06:55 AM   #13
Las Vegas , Nevada
Peter
Got it. I guess I need to see what’s there under the belly pan.
Old 09-28-2018, 08:32 AM   #14
Ask Airstream Engineers
I don’t know enough about the engineering of the framing of the Airstream. I think I would ask someone that engineers an Airstream at the factory. I wouldn’t talk to a dealer or even another person that has an Airstream.
As far as sway is concerned your Hensley will make your AS tow wonderfully. I have a propride and it makes towing so much more pleasant. But you will have a learning curve. I know I have. My last trip I think I have it adjusted just right with the gain, the tension on the WD bars, etc. It towed the best it ever has.
As far as hooking and unhooking the key is to back up as close to the trailer as possible. Then adjust the receiver to the right height. Then back in slowly. Back up camera will make it easy.
Unhooking is also critical. When you get your height adjusted correctly for hooking up then get a stick or pipe and cut it for the length that shows where you would be for no pressure on the hitch receiver. Then when unhooking just take off the tension of the WD bars, and raise or lower the hitch to that height. Then pull out. No problem.
One thing I wish that dealers would do is make that back up camera useable when unhooking as well. Would help in knowing what’s going on back there.
By the way you will need a 7 pin extender. My advice: buy 2. I had one of mine get caught some how on the hitch and crack. I was able to get a part to fix it. And thankfully it worked. No wires pulled off. But I decided that I better have a back up of that 7 pin extender. Cheap insurance.
Old 09-30-2018, 11:14 AM   #15
Las Vegas , Nevada
Thanks for the 411. My order included the 7 pin extender. May not need it as the present lead is long.
The Hensley Arrow is very logical to me. The only main unknown is hitching and un-hitching on ground that is not level and, or uneven.
Old 09-30-2018, 11:36 AM   #16
"Cloudsplitter"
You can tilt the hitch head side to side with the WD Jacks.
I use CW Hitch'n Rods and 'O' rings for setting height.👍
ID:	324071   Click image for larger version
Old 09-30-2018, 07:14 PM   #17
Still Dreaming
Manning G's Avatar
1971 29' Ambassador
Sulphur Springs , Texas
I'm in the 2 week process of rebuilding the rear of my '71 Ambassador. My problem was floor rot, but the process has convinced me that I will NEVER stress the rear frame.
Manning G is offline   Reply With Quote
Old 10-21-2018, 04:11 AM   #18
Retired Navy Submariner
1993 25' Excella
Ellicott City , MD
Very much appreciate the helpful posts!
I am looking for a used 4 inch offset (drop) hitch bar for my Hensley Hitch, and have a straight hitch bar to repurpose to someone. Any help or interest is appreciated. Thanks
frone is offline   Reply With Quote
Old 10-23-2018, 07:59 AM   #19
crispyboy's Avatar
1994 30' Excella
A welding fabrication shop should be able to modify what you have quite easily. Just show them a picture of the a 4 inch drop stinger and they will be able to replicate it.
WBCCI # 3072
Hensley or not hensley socool69 Hitches, Couplers & Balls 45 11-21-2014 08:28 AM
To Hensley or not to Hensley Aquabud Hitches, Couplers & Balls 86 12-22-2010 08:10 PM
Bought Used Hensley Arrow Dieselgrin Hitches, Couplers & Balls 1 11-20-2008 08:29 PM
5-year search ends. Bought my first Airstream! Silver Our Community 9 04-29-2003 05:35 PM
I bought an Airstream... now what? Swingking General Repair Forum 8 04-16-2003 07:52 PM
