RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-06-2018, 08:09 AM   #1
dznf0g's Avatar
Oswego , Illinois
Think I'll have a problem....
It rained "just a little bit" last night....a literal gully washer. This should be a fun hitching exercise. Click image for larger version
ID:	324548Click image for larger version
ID:	324549Click image for larger version
-Rich-
Old 10-06-2018, 08:30 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Yikes! Between the sinking of the trailer in to the mud and the new gulley in the drive - I agree youíre in for a heck of a hitch up. Do you have enough solid ground under the jack to get lift? If you have that, adjusting the jacks to tilt the head as needed will make this a bit easier - assuming your stabilizers didnít get buried under the shifting soil...
Good luck!
Old 10-06-2018, 08:46 AM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Looking at pictures sometimes will fake you out. That said, the jack foot and stabilizers all seem to be on top of the ground. At least you won't have to dig them out. The road in front of the trailer indeed took a hit. A shovel would be a good start there ...
Old 10-06-2018, 08:49 AM   #4
dznf0g's Avatar
Oswego , Illinois
Good luck!
Yeah, it solid under the jack and wheels, so far. More big rain coming. North of iowa city. It just going to be a very changing compound angle while entering the head. Gully is just about the same distance from the head a axle to receiver!
-Rich-
Old 10-06-2018, 09:08 AM   #5
Chelsea , Maine
Get a shovel and smooth out your approach.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 10-06-2018, 09:11 AM   #6
dznf0g's Avatar
Oswego , Illinois
Yeah, I carry a small folding army shovel for just this reason. I'll see if the cg has a tractor with blade. Since its on a hilside, this cant be uncommon.
I'll probably have to sacrifice some Lego blocks too.
-Rich-
Old 10-06-2018, 09:26 AM   #7
AFTER TAXES's Avatar
1964 22' Safari
1993 25' Excella
Flagler Beach , Florida
2x8 always under jack pad.......?????
AFTER TAXES is offline   Reply With Quote
Old 10-06-2018, 09:30 AM   #8
dznf0g's Avatar
Oswego , Illinois
Not sure what you mean?? I have the big AS aluminum plate under jack post
-Rich-
Old 10-06-2018, 10:20 AM   #9
2007 27' International CCD FB
San Diego , California
Guess I'm not really seeing a problem? At least with my setup, I've come across this type of thing and it's never been an issue?
Is the rut something your tow vehicle will have trouble traversing? Traction?
Is it a propride hitch alignment issue where they will be on different planes making hitch up harder with the stinger?
Boondocking Rig: '07 27FB Ocean Breeze "See Turtle"
Lexus LX570 on 33's - $1k 300Ah Lithium Upgrade - Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift
pteck is offline   Reply With Quote
Old 10-06-2018, 10:25 AM   #10
dznf0g's Avatar
Oswego , Illinois
Hensley, but yes. Pics dont show the severity if issue. Rear wheels will be in rut, about 8" deep. Front of TV will be about 12" higher than hitch mouth. Whole setup will be a good 8" off side to side. AS is on 4 legos on curb side. Itll be interesting. Radical change on all planes while entering head mouth with stinger.
-Rich-
Old 10-06-2018, 10:27 AM   #11
dznf0g's Avatar
Oswego , Illinois
I do have a wireless magnetic camera I place on stinger. That'll help some.
-Rich-
Old 10-06-2018, 10:35 AM   #12
I understand now. Wish you the best in getting her out!
I often boondocks on wildly cambered and irregular sites. So this type of thing is not uncommon to me.
Makes me think why normal hitches use a ball, such that coupling up at odd angles is never a concern.
Old 10-06-2018, 10:40 AM   #13
dznf0g's Avatar
Oswego , Illinois
Well, bro-in-law had trouble getting the bars off his equalizer too.
-Rich-
Old 10-06-2018, 10:50 AM   #14
Yes, anti sway and WD components can often get in the way when "off roading". The forces get pretty huge too as they are there to resist articulation.
I actually do also run an equilizer. I'll remove the WD bars first if I'm getting into something requiring articulation. In your type of case, I will usually pull her out, then fit the WD bars when back on level ground.
Don't mean to distract from your situation. Can you just fit the stinger first to pull out then apply WD? I don't have a Hensley.
Old 10-06-2018, 10:52 AM   #15
dznf0g's Avatar
Oswego , Illinois
Yes, I'm not concerned with getting out, and working wd later. Getting the stinger into the head will be hard. Patience, planning and thought will be needed.
-Rich-
Old 10-06-2018, 10:54 AM   #16
dznf0g's Avatar
Oswego , Illinois
4 wd low will be my friend, for those who think they will never need it
-Rich-
Old 10-06-2018, 11:08 AM   #17
W , New England
I had to use 4WD low to disconnect when I got here (wet fair grounds and on a slope front to back where my pro pride is flat on the ground and we still are angled a bit downward toward the rear...). And itís wet again today. May or may not dry out by Monday morning when we leave. But if a problem, Iím thinking I can hitch and back up until more level then pull out w/4WD low over the wet, muddy, rutted field....love a challenge (of course, if it doesnít go well, youíll hear my ďsailorís soliloquyĒ wherever you are....
Old 10-06-2018, 11:18 AM   #18
Glad you have it! I use low range more than half the time. It's just so much more controlled when dealing with irregular surfaces. No lurching, just precise controlled maneuvering, rut or not.
Old 10-07-2018, 03:34 PM   #19
dznf0g's Avatar
Oswego , Illinois
Got it out. Took about a half hour, a lot of brain cells and 8 Lego blocks in the rut and under the truck rear wheel. Got the stinger in up to about half way up the ramps and pulled it the rest of the way with the over center cams. 4wd low was absolutely necessary in this case.
-Rich-
Old 10-07-2018, 04:23 PM   #20
Nicely done. Glad you got her out. I've had my share of challenges and I look at them as part of the adventure.
My Kids think itís crazy, Grandkids think itís cool pdavitt Member Introductions 20 07-01-2017 04:05 PM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 02:39 PM
Think they have a problem? kamadeca Off Topic Forum 17 09-20-2010 07:42 AM
well i think i have a problem nkeeler Member Introductions 11 04-05-2010 07:28 AM
Ten Things I Think... I think hampstead38 1965 - 1969 Overlander 30 11-08-2008 08:48 AM
