Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 07-15-2006, 11:01 AM   #1
Gambierite
davida's Avatar
vancouver , BC
Always 2" 5/16 balls?
I'm in the process of buying an airstream, and getting ready to tow it back. My TV has a smaller ball hitch, and I know I need a bigger one from my memory of looking at the corresponding part on the 79 overlander. Someone mentioned the 2" 5/16 size, but I seem to find 2" balls as well on the net. Can I assume that 2" 5/16 is the right size for that vintage of AS?
davida is offline   Reply With Quote
Old 07-15-2006, 11:10 AM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Davida,
My 1979 Safari has a 2 5/16" ball, so that size is probably correct for your Overlander.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 07-15-2006, 11:11 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Gosh -- I forget the exact year. Airstreams did switch over to only the 2 5/16" ball after the mid-1960s. So this is the correct ball size if you're looking at anything from around 1970 or later (ask again if you're back in the '60s era...) The ball shaft should be 10,000 pound rated and you will see how very much bigger it is than a normal ball would have.
You should always check ball fit after hooking up by jacking back up. The hitch should pull the rear of your tow vehicle upward.
[On Edit:] There is no better source than Kevin! http://www.airforums.com/forums/131118-post5.html
5 meter Langford Nahanni
Old 07-15-2006, 12:41 PM   #4
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Send a message via AIM to Airboss Send a message via MSN to Airboss Send a message via Yahoo to Airboss
My 65 Caravel has a 2 inch but everything else has a 2 5/16 that I have ever owned. Yours will be a 2 5/16.....
Airboss is offline   Reply With Quote
Old 07-15-2006, 03:42 PM   #5
Gambierite
davida's Avatar
vancouver , BC
Smile Thanks
Thanks all.
Old 07-17-2006, 10:07 AM   #6
Hind-Sight's Avatar
Murray , Utah
The 69 Overlander I picked up yesterday required a 2" ball. I was prepared with both and expected it to be 2 5/16" and was surprised that it was 2".
Andy S.
Murray, Utah
69 Overlander
01 Suburban
Hind-Sight is offline   Reply With Quote
Old 07-17-2006, 10:29 AM   #7
Retired.
. , At Large
Most Airstreams went to 2 5/16" with the introduction of the newer body style in 1969, although the occasional "exception that proves the rule" shows up from time to time.
Old 11-26-2006, 01:35 PM   #8
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
1968 ball size
I will be picking up our "new" 1968 sovereign this week. I have quite an assortment of balls and hitches but I would like to take only 2" or 2 5/16 If I can determine witch it will be for sure. The seller said 2" but did not sound very sure. Does any one know for sure? Seems to me they would have use the larger balls on such a large trailer.
Thanks Phil
Phil Gobie is offline   Reply With Quote
Old 11-26-2006, 01:43 PM   #9
1960 24' Tradewind
santa barbara , California
Sonds like you need to take 2 balls along 2" or the 2 5/16 just to be sure.
You can just put the loose ball up in the coupler when you get there ,one will not fit if its 2" .
Scott
scottanlily is offline   Reply With Quote
Old 11-26-2006, 09:06 PM   #10
1995 30' Excella
Chewelah , Washington
My 1969 Overlander also a 2" ball and does not look to have been changed, Was a CA build AS. I keep seeing that the change was made in 1969, but was that at one plant, or all plants as also see other 1969's that have the 2" inch ball pop up on here. Or a midyear change?
gmshadow is offline   Reply With Quote
Old 11-27-2006, 05:49 PM   #11
Retired.
. , At Large
The changeover was supposed to have happened at the same time the new body was introduced, but it looks like some '69's got out of the factory with 2" couplers on the tongues (I guess they didn't read the memo).
I have learned never to go with only what the trailer was supposed to have on it. I have seen 1 7/8" balls all the way up to something I didn't even have (2 5/16" fell out when I put it in the coupler).
Old 11-27-2006, 05:59 PM   #12
1975 29' Ambassador
Reno , Nevada
The shank size can be a problem. With the 10k ball rating you will need a ball mount with a larger hole - inch and half shank, 400 lb-foot torque on the nut if I recall correctly.
Old 11-27-2006, 06:12 PM   #13
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Wow, can you rent a 400 ft-lb torque wrench. I think those would be really expensive to buy. Seems I read $400-600 somewhere on this forum one time.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
Old 11-27-2006, 09:18 PM   #14
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
There are doohickies called torque multipliers that diesel shops use. They go between the torque wrench and the nut. 200 ft-libs is about much as I've seen for the wrenches but they up to 600 lb-ft, I've heard.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 12-03-2006, 07:43 PM   #15
cookeville34's Avatar
Auburntown , Tennessee
Send a message via Yahoo to cookeville34
My 1979 Airstream Sovereign 31' has a 2" hitch, when I went to pick it up all I with me was a 2 5/16 ball. I spent two hours going house to house looking for a 2" ball, finally an old farmer had one. Carry both a 2" & 2 5/16". Airstreams appear to be like Studebakers there are always factory oddballs and dealer changes. My trailer is not supposed to have an astradome skylight, but it does.
1979 Airstream Sovereign International, 31'. VIN# I31T9J0162
1992 Buick Roadmaster Wagon, 5.7L - V8, stock 5000# tow rating, posi, aux trans cooler, rear coil over shocks, 2" rear spring lift kit, flowmaster exhaust.
cookeville34 is offline   Reply With Quote
Who has a 2" drop with leaf springs? TravelCloud Axles 3 04-14-2005 01:06 PM
2" Receiver at rear of Airstream? BeBop Hitches, Couplers & Balls 5 08-23-2004 09:13 AM
Nice Balls Tin Hut Hitches, Couplers & Balls 6 07-11-2004 02:32 PM
Speaking of hitch balls Ken J Hitches, Couplers & Balls 11 10-18-2003 09:09 AM
Moth Balls niftypkg General Interior Topics 10 02-03-2003 10:15 AM
