Old 09-03-2007, 06:25 AM   #1
"Cloudsplitter"
Worthwhile Up-grade
This is an up-grade that will make a real difference when towing your A/S.
At 39k miles I replaced the OEM shocks on our 95 Burb with the Edelbrock IAS, a real noticeable improvement. The inertia valve reacts instantly to abrupt changes too road conditions, as in pot holes or obsticles,but under a constant load, as in braking,turning,or dip's in road surface they stiffen substantially.
We now have about 170k on the Burb and the second set was installed at 129k. So at about $80.00 bucks apiece, I think it's a pretty good deal.
Be safe........Stream-on!!!!
Edelbrock.com - Shocks
Name:	towing accessories 001.jpg
Old 09-03-2007, 11:00 AM   #2
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Compared to Bilsteins? I have a 2008 Ford SD and will replace the Continentals with the new Michelins and the stock shocks with Bilsteins. I used the Bilsteins on my 96 Burb and loved them.
altamont is offline   Reply With Quote
Old 09-03-2007, 11:08 AM   #3
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Culpeper , Virginia
I recently replaced the OEM rear shocks with Bilsteins. Made a huge difference. got 24k on the no-name OEM tires. Ready to replace them with 255.70.17 Micheline LTX M/S
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 09-03-2007, 05:58 PM   #4
altamont's Avatar
Tracy , California
New Michelins for truck
I have heard good things about the new Michelin LTX® A/T2 Tires.
They supposedly ride much better and are very quiet.
Old 09-03-2007, 06:50 PM   #5
"Cloudsplitter"
Bilsteins-good Choice
Bilstein's are a good choice, but would recommend replacing all four at once.
Old 09-03-2007, 07:43 PM   #6
altamont's Avatar
Tracy , California
Old 09-03-2007, 07:50 PM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I have a brand new set of Bilsteins on ebay, btw. They are from my 1997 1500 2wd Suburban.
Uwe
www.area63productions.com
Towing up/down a steep grade Tin Diesel Tow Vehicles 9 09-03-2007 03:41 PM
TV Up-grade Robfike Classic Motorhomes 8 09-20-2006 03:10 PM
Do you think I need a coarser grade of Nuvite than G6? 72Blazerod Cleaning, Stripping & Polishing 13 07-02-2006 10:52 PM
Worthwhile upgrading Dual-cam? SafeHarbor Hitches, Couplers & Balls 8 06-18-2006 06:29 AM
Fuel Grade jaiman Mechanics Corner - Engines, Transmission & More... 18 09-29-2003 06:11 PM
