04-27-2012, 07:15 AM
#501
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Originally Posted by Globie64
...I think you wouldn't want to add too much to that frame, like a 383, even with a new clip...
Big block Chryslers are not heavy engines. They are closer in weight to a small block Chevy. They're actually even easier to work on than a small block Chrysler (or Chevy for that matter). For instance, changing a water pump is a piece of cake compared to most engines.
Vaughan
04-29-2012, 05:27 PM
#502
Durango
Here's a Viper in a '48 Chrysler Town & Country. Chassis is from Art Carr. Used my T&C to haul a 1942 Chris-Craft.
04-29-2012, 06:06 PM
#503
Moderator dude
1966 26' Overlander
Phoenix
For $16K you could have this delivered. Then let the games begin.
2006 DODGE VIPER SRT-10 PARTS SALVAGE CAR XVIPERS OEM GEN 3 GEN III | eBay
Officially the Viper does not have a tow rating. And that doesn't mean the engine isn't set up for it. Because there is more to a tow rating than an engine. (Suspension, brakes, steering and the frame as well) The Dodge Viper was not designed for towing at all. And I would suspect that engine isn't a great source for towing loads over 2000#s anyway. That is a guess on my part. And it would be very cool and have a lot of appeal. YOu would have to drop some serious coin to make that happen.
And my point is you could drop some serious coin for a pristine stock New Yorker T& C that may fetch $25 to $30K on re-sale. I know you don't have that in mind. Going down that road means you have a one of a kind or nearly one of a kind. And it's only money.
>>>>>Action
04-29-2012, 06:23 PM
#504
Durango
Originally Posted by Action
For $16Gs you could have this delivered. Then let the games begin.
Officially the Viper does not have a tow rating. And that doesn't mean the engine isn't set up for it. There is mor eto a tow rating than an engine. (Suspension, brakes, steering and the frame as well) The Viper was not designed for towing.
>>>>>Action
The first Viper engines were based on the Dodge Truck V-10. Cast in aluminum, a lot of the innards were supplied by speed equipment manufacturers. So, check the tow rating of a '96 Dodge truck and you're in business!
04-29-2012, 06:47 PM
#505
1975 Argosy 26
1963 24' Tradewind
Seattle
Bredlo... nice Town and Country! I think I saw your into on the HAMB... think you got hit a little hard by the tow police there! Some thoughts.. I'm not sure of your budget, but a 360 would be cheap to buy. Also a a518 AOD from a mid 90's Mopar van or truck would be an easy OD tranny to put behind it. Here's a thread that someone put behind their polyblock v8. Seemed pretty easy to do. Sweptline.ORG • Login
Also, look at Rusty Hope for a disk brake conversion for the front. I used his kit for the front of my '55 Dodge C3 pickup and it's both easy and a sturdy kit. I saw another member on the HAMB used it on his T&C as well.
Look forward to seeing this go forth! Can you pm me a thread link if you decide to put a thread up on some forum?
I like it a lot!
Marc
04-29-2012, 07:16 PM
#506
Foothill Ranch
Tow vehicle + Engine swap = Diesel.
No other way to go unless you are just playing.
I agree with the 5.9 Cummins swap, in 12V or 24V guise.
Lets face it, 600ftlb and 25mpg is so cheap and easy.
05-01-2012, 03:24 AM
#507
1966 28' Ambassador
St Kilda
, VIC
Vintage Tow Vehicle Question from Australia!
Hi Everyone,
This is an amazing forum! I have spent hours trawling over all the posts and admiring your photos! I apologise if this question has been answered before, but I could not find it
I have just been given the wonderful task of finding an appropriate tow vehicle for my boss's 1966 Airstream Ambassador and he is keen on a 1950s Chevy Ute ( something like this). Our mechanic has told us though that pre 1970s vehicles would be too weak to tow the Airstream because it's chassis is not strong enough. I have seen many of your photos with beautiful vintage cars towing your caravans, so my question is: and a 50s ute tow a '66 Ambassador? If not, what vintage (i.e. curvy) vehicle would suite?
Any help on this would be greatly appreciated!
Airstream Novice,
Simon
05-01-2012, 08:44 AM
#508
1974 25' Tradewind
Ann Arbor
, Michigan
Simon, there are dozens of models of vintage cars and trucks with perfectly adequate frames. Unibody cars need thought put into the hitch receivers, but there are many with plenty of strength to do the job.
05-01-2012, 10:48 AM
#509
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Originally Posted by SimonM
Our mechanic has told us though that pre 1970s vehicles would be too weak to tow the Airstream because it's chassis is not strong enough...
My concern would not be the frame, but the brakes. However, original brakes can be, upgraded to disk systems. It's not that uncommon in even mild hotrodding.
Vaughan
05-01-2012, 11:18 AM
#510
St. Catharines
, South Western Ontario
Airstream Novice,
Simon
You can get you mechanic up to speed by showing him this pic from the late 50's....
05-01-2012, 07:36 PM
#511
1966 28' Ambassador
St Kilda
, VIC
Thanks for the advice guys, it seems there is certainly hope for us getting the perfect tower. One more novice question:
How do I calculate the towing capacity of vintage cars/pickups? Is there a calculation? It just doesn't seem to be listed under the specs of many older cars.
Simon
05-01-2012, 07:46 PM
#512
Sioux Falls
, South Dakota
Interesting! Quite a few spare tires and wheels mounted at the rear. They must have made better trailers then. Or lighter wheels.
05-01-2012, 08:26 PM
#513
1954 22' Safari
Deerfield
Originally Posted by Keyair
I agree with the 5.9 Cummins swap, in 12V or 24V guise. Lets face it, 600ftlb and 25mpg is so cheap and easy.
I'd sure be the king of tow vehicles... but I just watched a few YouTube videos of Cummins engines and I'm not sure I can handle that "Big Rig" soundtrack everywhere we go. Cripes they're noisy. Tempting amount of power, though.
Originally Posted by 3Ms75Argosy
Bredlo... nice Town and Country! I think I saw your into on the HAMB... think you got hit a little hard by the tow police there! Some thoughts.. I'm not sure of your budget, but a 360 would be cheap to buy... Here's a thread that someone put behind their polyblock v8.
Marc, that link didn't show up - I'd love to see more example projects than the couple I've found, if you can find it again.
And yes, the "tow police" were out in full force on the HAMB. Strangely, none of them make a peep when you get home safely... I think they secretly wish I'd wrecked it just so they could cheer, "Toldyaso!"
Get an entire high mileage (100k miles) doner vehicle that was rear ended and the sheet metal is ugly... Getting an entire ride means you have all of the engine management pieces. Wiring, sensors, vacuum lines and related parts....
I've heard this advice more than once now, and I'm inclined to think it's pretty smart. It's just a matter of picking the right donor - I don't know where to begin.
...if it were me, I would stick with the six and find a hefty stick shift to tow an under 20' Airstream...
And know there is a market for anything and everything you take off no matter what the condition.
Thanks for all the great tips, Action! We already have the '54 Safari... so I think a V8 is simply going to play better when we head into the mountains. That said, this little straight 6 will be fun to take to Friday night cruise-ins for the next couple months, anyhow. And maybe it can help fund the project since it's running perfectly.
Mopars rock! The old hemi will be harder to source parts for- I have a 68 with a 318...
...That said your T and C is amazing, and will make a super tow vehicle!
Thanks Globie - you make good points, and I think I'll probably stay away from a period Hemi when a new crate one would be better in several ways (IMHO).
Holy moly, Dennis. That T&C / Chris-Craft combo is just stunning.
As for the Viper V-10, I've gotta think there are more MPG's in something a bit less, um, serpentine? Would be a blast coming out of stoplights, though.
Thanks everyone!
05-01-2012, 10:14 PM
#514
Moderator dude
1966 26' Overlander
Phoenix
Simon
Towing specs as we know today did not exist prior to the 80's. In the late 70's the CAFE standards were enacted so the job of weight movement slowly began shifting from passenger cars to something else. (Trucks, vans and SUVs)
Speaking from Ford Motor Company products, towing specs were mostly listed in the owner's manuals for models in the 60's and 70's. (I don't have much experience with previous years) I have the factory towing specs for all FLM products in 1966 and the required equipment. Most of the equipment could be added to a vehicle so not equipped. Other manufacturers not so sure.
>>>>>>>Action
05-02-2012, 03:13 PM
#516
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
I see no problem...
I got a car that outweighs the Flying Cloud...by a lot. An aluminum radiator with dual electric fans; rebuilt the transmission; transmission cooler; air shocks and dual disc power brakes; rebuilt the motor just in case; special designed hitch with all new brake wiring system; etc. etc. We call that overkill.
I seem to remember a trip across the USA in a new 54 Buick Roadmaster towing a trailer....it had a bolt on the bumper hitch....thats it. Oh...and a canvas water bag hanging off the front of the hood/bumper. Never had a problem.
05-03-2012, 02:46 AM
#517
1966 28' Ambassador
St Kilda
, VIC
What are your thoughts on this beauty: 1953 Ford Mainline Utility
It's got an L-head 239-cid V8 with a compression ratio of 7.2:1 and developed 110 horsepower at 3500 rpm, a three-speed manual transmission standard, with synchro on second and third.
Do you think that engine is big enough to tow out 2.5 ton (5000pound) Airstream?
Simon
05-03-2012, 07:54 AM
#518
Scottsdale
My New TV 83 Suburban
I found it on Craigslist. It has a 454 crate motor with 54K miles on it.
Trailer Geek
'70 Streamline Duchess
Toyota Sequoia SR5
'58 Shasta Canned Ham
05-03-2012, 07:57 AM
#519
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Simon
Well, it was built with L-head 239-cid V8 with a compression ratio of 7.2:1 and developed 110 horsepower at 3500 rpm, a three-speed manual transmission standard, with synchro on second and third.
It has a 302 Cleveland and a C10. Even better. Disk front brakes too.
Very cool! Thanks for sharing.
Vaughan
05-04-2012, 12:58 AM
#520
1966 28' Ambassador
St Kilda
, VIC
Haha, good pickup! Now it looks even better!
