03-09-2014, 11:22 AM
Burke
, Virginia
Help a noobie -- Nissan NV passenger van
Would someone please help me determine if a Nissan NV passenger 3500 SL van with 5.7L and OEM tow package with an advertised tow rating of 8700 pounds, a GVWR of 9520, a curb weight of 6862, a GCWR of 16,000, and a max tongue weight of 870 would be able to safely tow a 25' or 27' front bed airstream FC with a GVWR of 7,300 and 7,600 respectively. Here are the assumptions:
--We're going to be towing A LOT (20,000 miles a year)
--I will be using a hensley or Pro pride WD hitch
--We (passengers) weight 500 lbs combined
--I would be removing several of the rear-most seats from the van (it has seating for 12), freeing up prob another 300 lbs. of payload.
--I want a good deal of safety margin and cargo carrying ability
--Yes, I know the van is ugly
I know it will "pull" it, but I want to know if it can safely control and stop it and stay under weight limits.
Thanks… this stuff is so confusing for a newbie.
03-09-2014, 11:58 AM
Alamo Heights
Just glancing at the number it looks like you might be close on the GCWR with the 7600 lb trailer and much more than passengers in the van, but that's not why I initially though to comment.
The Nissan 5.7l has proven to be quite thirsty in the Titan, and you said you're planning to do "a lot of towing." It might be worth looking up Titan fuel economy when towing... if it's the same 10-ish MPG that most 5-6 liter pickups return when towing, it probably doesn't matter, but it's something to check.
— David
03-09-2014, 12:03 PM
Burke
, Virginia
That's good advice. Luckily I don't own either the AS or the TW yet. We really don't want a pickup and there will be times we'll want seating for more than 5 (not while towing). I don't see much else out there.
03-09-2014, 12:56 PM
1984 34' International
Toronto
, Ontario
How about the Ford commercial vans? Ample seating, and the tow ratings you're looking for. Also, ample weight carrying capacities.
03-09-2014, 01:10 PM
2013 30' Classic
Greenwood
, Mississippi
What about a 3/4 ton or 1 ton Chevy Express/GMC Savana?
Very capable and a little less ugly...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
03-09-2014, 01:16 PM
Burke
, Virginia
Is that an official "no" for the Nissan's capabilities? Even for a 25fb?
03-09-2014, 01:24 PM
2013 30' Classic
Greenwood
, Mississippi
No, it's not a no...
I don' really "know" a lot about them except that they are ugly...
Imhaven't seen an NV towing a trailer, yet, but I have seen Titans, Armadas, Pathfinders, and Frontiers towing travel trailers...
I'm sure an NV could, too, but, wow! That thing is unbelievably ugly...
Whatever Ford's new van is, maybe a big Transit Connect, may be capable- I don't know-
Or the new Ram Pro- I don't know-
The Ford Transit or Ram Pro might be as ugly as the NV...
But I do know about the Express/Savana...
TAC #MS-10
Airforums #70955
03-09-2014, 01:25 PM
Toronto
, Ontario
Real world capabilities and numbers are often two very different things. Were it me, I'd tow both a 25' or a 27' with a Sienna or Odyssey.
However, it sounds like it's important to you that you stay within the manufacturer's published capabilities. The Nissan should work out just fine, just as the other commercial vans.
In the end, it's a personal choice. Looks, fuel economy, payload, I'd go and compare.
03-09-2014, 01:40 PM
Burke
, Virginia
Thanks everyone. So I'm guess right now I'm just looking for a definitive answer if either of those AS (25 or 27/28) would put me over any official published limits of the Nissan NV. If it does, or it's too close for comfort, then I'll bail on the idea.
03-09-2014, 01:45 PM
2013 30' Classic
Greenwood
, Mississippi
I think any Airstream of that length will exceed the tongue weight of the NV.
If you will exceed the tongue weight anyway, you can get a 30- the 30 has less tongue weight than some 27's...
TAC #MS-10
Airforums #70955
03-09-2014, 01:50 PM
Burke
, Virginia
Sorry for all of these questions. So even if you use a WD hitch, are you still trying to stay within the tongue weight rating from the vehicle mfg or is that published number just for using a traditional ball hitch?
03-09-2014, 02:13 PM
2013 30' Classic
Greenwood
, Mississippi
The weight distributing hitch will transfer some weight to the tow vehicle's front axle and some weight to the trailer's axles.
I don't really know how to calculate those weights without having the tow vehicle and trailer and making a trip to the Cat scales- make a pass with weight distributing hitch and a pass without-
It would be nice if you could hear from someone using a Nissan NV.
TAC #MS-10
Airforums #70955
03-09-2014, 02:20 PM
Burke
, Virginia
OK, I see. So that's the hard part is you won't know until you buy and weight it. But then it's too late. So maybe the only way to go is to go overkill. What's reasonable overkill on a 25' - 28' AS? A 2500-series pickup with a tow package and a Diesel?
03-09-2014, 03:26 PM
2013 30' Classic
Greenwood
, Mississippi
Pretty much...
Or if you want a van a 2500 or 3500 Express/Savana...
TAC #MS-10
Airforums #70955
03-09-2014, 03:27 PM
2013 30' Classic
Greenwood
, Mississippi
Do you currently own any vehicle capable of towing?
Are you starting from square one on trailer and tow vehicle both?
TAC #MS-10
Airforums #70955
03-09-2014, 03:38 PM
Burke
, Virginia
Have not purchased trailer yet. I have a 2012 X5 Diesel that I purchased new, currently with 33k miles. Believe me, I would love to use this vehicle and be done with it. It has a 3rd row seat with air suspension, so its specs are a little higher than a 5 passenger model. Here are its specs from the door placard:
Payload not to exceed 1290
GVWR = 6581
GAWR rear = 3858
Can I *safely* and within published limits tow a 25? If not, what about a 23D?
03-09-2014, 04:14 PM
2013 30' Classic
Greenwood
, Mississippi
There are people,on here that tow with an X5 or a Touareg.
I have seen Dodge Dakotas and Durangos towing.
TAC #MS-10
Airforums #70955
03-09-2014, 04:27 PM
Burke
, Virginia
I know people do it. But I dismissed it early on bc I'd be over on the tongue weight alone. Plus the mfg doesn't support a WD hitch. And I'm still in warranty for 18k miles. Too bad my family of four won't fit comfortably in a 16' Bambi or I'd be set.
Thanks for all your input.
03-09-2014, 04:35 PM
2004 25' Classic
Prescott
I use an Infiniti QX56, which has the same 5.6 motor. Gas mileage is right at 10 cruising at 70 mph. The only spec. that will be close is the tongue weight. I believe mine is rated the same and I know my tongue weight is right around 1,000 - 1,050 lbs. I figure with the WD hitch, I am taking a good 400 lbs. off. I also know they say you can not do that and to use what the actual tongue weight is, but I just do not see it that way. I also am considering the NV, because of it's load capacity, but it sure lacks in eye appeal.
Julia & Bob
W/ Deedee & Boo
AIR #30685
03-09-2014, 04:47 PM
Toronto
, Ontario
The X5 makes an excellent tow vehicle, for all kinds of trailers. There are several members on this board who live theirs.
