Prev Previous Post   Next Post Next
Old 02-24-2009, 08:33 AM   #1
cbgenrich's Avatar
Profile:  Currently Looking...
Atlanta , Georgia
Limited slip axle - must have?
It's not the cost ($300), but the constraint. The choices are these:
1) 3.15 Non-limited slip axle ratio
2) 3.55 Non-limited slip axle ratio
3) 3.55 Limited slip axle ratio
4) 3.73 Limited slip axle ratio
I know that higher ratios tow more weight, and lower ratios get better fuel economy and are somewhat quieter to drive in non-towing situations (lower RPMS).
Seems like 3.55 is the way to go, rated for 9700 lbs, in case I want to pull some bigger Airstream some day, without being overkill. It's also the most common and available.
Is there a down side to having limited slip?
If I buy a new truck with non-limited slip, will I regret it? Is limited slip a must have?
-CB-
cbgenrich is offline   Reply With Quote
Slip Dolly JimGolden Hitches 13 06-21-2009 03:38 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 11:37 PM
Slip Fitting On Top Of Black Tank To Toilet Radman Sinks, Showers & Toilets 3 05-02-2007 04:11 PM
85 Limited robandzoe Cleaning, Stripping & Polishing 2 05-28-2004 06:00 AM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 05:15 AM
