Old 03-21-2015, 04:52 PM   #1
sequim , Washington
Factory indicated truck computer updates
several months ago now, i had a service done on my 2014 F350 diesel. the service mgr said there was an 'update' indicated for my vehicle. so he went ahead and applied the update, i assume some sort of onboard computer patch.
what has happened is a reduction in fuel economy of 2 MPG either towing or just running.
has anyone else had this experience???
i intend to call in on Monday to see if there is a patch for this last 'update'.
reelfastgreg is offline   Reply With Quote
Old 03-21-2015, 05:39 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I recently had 12 updates flashed on my Jeep. As far I can tell there are no obvious changes in performance or fuel usage.
MICHAEL
Old 03-21-2015, 05:54 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Take it to a Speed Shop and have them reprogram it. They can more than likely improve it over the original.
I have mine set up for an additional 30 hp and increased the mileage about 1 mpg. 13 mpg average totaling 16,700 lbs
If you want them to install a system so you can reprogram it yourself and or get gauge readings and codes from the CPU directly on the dash that is very helpful. I can tell a shop what codes I have set before I get there.
2004 Excursion 4x4
Old 03-25-2015, 03:59 PM   #4
sequim , Washington
spoke with the Ford customer support person someplace in India. the gentleman upgraded my concerns to the next level. the female voice asked if the dealer had inspected the truck for things that might not be functioning correctly, nope. so tomorrow, early AM, i am driving back to the dealership where they will re-install this update and in general look for any other computer indicated faults. my supposition, loss of mileage will remain, and i will call the support line and report my findings.
Old 03-26-2015, 10:56 AM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Same thing happened on my dodge,each programming lost fuel mileage, it sort of come back after quite a few miles,if it runs good ,leave it alone....
Old 03-26-2015, 11:31 AM   #6
dznf0g's Avatar
Oswego , Illinois
If other mfrs are similar, and I think they are, many reflashes reset the fuel trim and ignition algorithms to a baseline. It takes up to 1000 miles to "learn" the drivers' driving style and demands.
That being said, depending on whether the driver has a heavy or economical foot, mileage can go up or down from baseline.
-Rich-
Old 03-26-2015, 02:32 PM   #7
gecko's Avatar
2009 28' International
Pacific Palisades , California
You're going down the right path. Software upgrades to anything are often not seamless!
We had a check engine light come on on our new Mercedes Sprinter while 1600 miles from home. Went in to the local dealer, who spent six hours checking out codes and then installed an overall software update. When he tested it, it shut down the turbo entirely! So he reinstalled the software and rebooted, and all was fine.
The problem turned out to not be software related at all, and was detected when the conscientious tech spent an hour going over the undercarriage and found a loose wire that had been chafing against the axle. A fifty cent part, and we were good to go. Just out a day of sitting around!
gecko is offline   Reply With Quote
Old 03-26-2015, 03:05 PM   #8
iowaroots's Avatar
Dallas Center/Des Moines , Iowa
Mileage
Could it be that winter fuel gets less mpg than summer fuel. It seems to be the case in the midwest.
iowaroots is offline   Reply With Quote
Old 03-26-2015, 03:15 PM   #9
sequim , Washington
that is an interesting point that i had not considered. had the work done this AM and on the road back home, 1.5hrs, i didn't notice any improvement in fuel economy. that said, i will put some miles on the truck before i pursue this much further.
Old 03-26-2015, 03:16 PM   #10
sequim , Washington
that is another interesting idea that has merit regarding what i am currently seeing. i have no idea if we are still on winter blend or not but worth checking into that as well.
Old 03-29-2015, 06:25 PM   #11
Trying to run away.....
Hampton , Virginia
As addressed above the PCM is relearning the tables it uses daily. I second the winter fuel blend statement. Not only does that effect the MPGs but so does the cold air. Now you may need to wait till April/May but only you know your market when they switch up the supply.
I'm quite well versed on the Powerstrokes to tell you to just drive it. Give it time and maybe wait for the summer blend. You could try a fuel additive such as Power Service or Howe's, maybe use the Ford stuff. The Ford update has been to address the issue with the EGT sensors leaving people stranded. The parameters have been adjusted from my understanding to prevent a total shutdown of the truck.
HeavyAssault is offline   Reply With Quote
Old 03-29-2015, 06:57 PM   #12
r carl's Avatar
Lin , Ne
Could it be that they are in cahoots with big oil?
Old 03-29-2015, 08:54 PM   #13
dznf0g's Avatar
Oswego , Illinois
Yeah, I'm sure that's it........
-Rich-
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Power problem indicated by "weak" microwave? davida Batteries, Univolts, Converters & Inverters 4 06-12-2007 01:23 PM
High oil pressure indicated on gauges Mr. D Mechanics Corner - Engines, Transmission & More... 11 11-02-2006 11:28 AM
Region 9 Computer Rally Pahaska WBCCI Rallies & Events 2 03-01-2003 10:41 PM
