Old 12-30-2014, 04:16 AM   #41
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I disagree. I think buying more expensive tires that I'll never get to use half the tread is throwing money away. If I had lots of money, maybe I would run Michelins on everything, but I don't have lots of money, so I get second best and less expensive.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-30-2014, 05:08 AM   #42
Vintage Kin
Fort Worth , Texas
It's the on road performance and reliability. That you don't want to is fine. I'm not willing to chance problems with tires on the TV. My truck is not ever less than 87% of GVWR. Over five years the annual cost increase is minimal. And the reality of hurricane evacuation makes it easy. One gets what one pays for in tires.
from the AIRphone
Old 12-30-2014, 12:56 PM   #43
m.hony's Avatar
2013 30' Classic
Never had a problem with Bridgestone or Firestone.
I will not by Goodyear because I have had problems with them.
I have had cheap tires and had good luck with them- Multi-Mile, Turbo Tech, Grand Am Radial GT- but I don't see these tires for sale anywhere anymore.
Every time I get new tires, the tire store recommends Kuhmo or Yokohama. I don't know if they recommend them because they're good tires or they make more profit on them-
Obviously you have more money than me, but if you have $1 you have more money than me-
TAC #MS-10
Airforums #70955
Old 12-30-2014, 12:59 PM   #44
m.hony's Avatar
2013 30' Classic
Let me modify my statement-
Never had a problem with Bridgestone-
Firestone are noisy rolling down the highway, but the tread lasts a long time.
I have had some Sears Guardsman tires that were terrible.
I consider Bridgestone second best to Michelin and good enough- unless I can get lucky and get Michelins at or near the same price-
TAC #MS-10
Airforums #70955
Old 12-30-2014, 01:58 PM   #45
Vintage Kin
Fort Worth , Texas
If I was running a half ton Id be less concerned. Duravis or LTX on the possibility of unpaved roads in event of evac. As said, cheap over the years. Having these trucks commercially I find the two above will take most anything.
from the AIRphone
Old 12-30-2014, 03:12 PM   #46
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Which Michelin LTX?
Originally Posted by kingfisher24 View Post
i took off the original maypops and replaced with michelin ms LTx(LESS THAN 200 EACH)…it was a new truck…20" tires that come standard OEMs with them ARE DANGEROUS…...
2013 GMC sierra denali
What size tire did you get? Is it an "LT" tire or a "P" rated tire? When I looked up what Michelin had available in the tire size on my vehicle, they only offered a P rated LTX MS/2.
SSquared is offline   Reply With Quote
Old 12-30-2014, 03:30 PM   #47
2007 22' International CCD
Firestone tires tried to kill me and my family. True, they don't make the same tires anymore, but I have never had any issue with Michelin tires on any vehicle. So I put Michelin on any of my vehicles before the OEM stuff even starts took worn or tired.
Rather not take the chance.
Old 12-30-2014, 04:39 PM   #48
m.hony's Avatar
2013 30' Classic
I had 2 blowouts on Michelins on a 1995 Chevy G2500 van (separate occasions a couple of months apart). Both were on a really long bridge in Louisiana (Lake Ponchartrain Causeway one time, I-12 between Hammond and Baton Rouge the other time- maybe extreme heat was a factor). Blowouts can happen with any brand of tire.
I do still believe Michelins are the best, but second best is good enough for me.
TAC #MS-10
Airforums #70955
Old 08-08-2015, 07:42 AM   #49
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Anyone have the Michelin Defender LT 285/60 x 20? This is the only 20" tire by Michelin I could find on Tire Rack.
Looking at a 2015 Ram 2500 Big Horn but it comes with 20" rims.
Kelvin
Old 08-08-2015, 08:21 AM   #50
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Firestone Transforce HT 285/60x20
Old 08-09-2015, 02:04 PM   #51
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Kelvin
I haven't used the Defender LTX but I'm glad to see they also make them in a 265/60-20 size that will fit the 2015 GMC with 20" rims. Nice to to have another option.
These are a new tire and Michelin describes them as a latest generation LTX (with Evertread compound) , so hopefully they will prove to be as good as the original LTX........... Defender LTX M/S
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 08-09-2015, 02:59 PM   #52
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
I am wondering about ordering the optional 20" wheels. Are there any advantages to the larger wheels other than looks? Is the ride quality better or worse with the larger wheels? It is a pricey adder.
Just got a '15 F-150 with 20". The diameter is 1.3" more than the standard tire/wheel so there is not much difference. Low profile tires rider rougher and the larger wheels lower the rear axle ratio and RPM a bit. My 3.55 is now a 3.39. The mileage should be a bit better by a 0.5 mpg or so. I do not believe there is much profile compromise. My stock tires are 20" version of the Michelin LTX MS/2 which is what I have on the trailer and had on my previous truck.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
Old 08-09-2015, 04:18 PM   #53
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Sorry, Transforce AT 285/60x20.
My brother-in-law, who just retired from AT&T says they use this tire on their service 3/4T trucks, which are never checked for alignment and are abused and they get long live out of them.
Kelvin
Old 08-09-2015, 04:20 PM   #54
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
With 20" rims common on 1/2T and 3/4T trucks I think in the next 2 yrs to 4yrs we'll see other manufacturers will step up to the plate.
Kelvin
Old 08-09-2015, 09:18 PM   #55
m.hony's Avatar
2013 30' Classic
A Firestone TransForce HT Load Range E 10 ply 20" tire to fit my odd sized Tundra wheels would be awesome.
TAC #MS-10
Airforums #70955
Old 08-09-2015, 09:19 PM   #56
m.hony's Avatar
2013 30' Classic
We use the Firestone TransForce HT on our fleet of 400 or so trucks and 50 or so trailers, but they are mostly 16" wheels. Some 17's and 18's are getting in there on the newer models.
TAC #MS-10
Airforums #70955
Old 08-09-2015, 10:13 PM   #57
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Firestone TransForce AT offer both20" and 18". Diameter is .2" larger, weight 5lbs more on the 20", the 20" has 1/16" less tread depth. Both rated at 3640lbs at 80psi. 20s cost $38 more.
I measured the height of a Ram 2500 CC with 18" and 20" rims and the distance to the bottom of the receivers were the same, 23".
Kelvin
From 14" wheels to 16" wheels Air Cruiser Wheels, Hubs & Bearings 24 09-16-2011 07:18 AM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 05:31 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
