Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 03-30-2011, 07:05 AM   #21
1995 28' Excella
Mobile , Alabama
Originally Posted by Sean Moore
I read a couple replies and figured I could sum it up in one sentence:
Don't buy your Pergo from the big box stores and make sure you have to glue and strap it.
Seriously... Pergo isn't like Kleenex. You're not going to get the same stuff from different stores. The click laminate is crap... all of it. There is glue together laminate still available in both thicknesses to this day. Just use the 6/7mm stuff for an RV, no need to go to 10/12mm, that's for commercial use.
If you're not wiping glue off of the surface as you're installing it, you're not using enough glue. Rent the strap clamps.
edit: the above advice comes from a floor professional, not an RV professional.
HOW MANY BOXES DID IT TAKE OF BAMBOO? FOR PERSON THAT INSTALLED IT?
Sent from my iPad using AIR Forums
ritasmith52 is offline   Reply With Quote
Old 03-30-2011, 08:00 AM   #22
64GlobeTrotter68Overlande
man7sell's Avatar
1964 19' Globetrotter
1969 27' Overlander
Snohomish , Washington
2 boxes plus one piece for a Globe Trotter
Capt. Paul Mansell
1964 Globe Trotter
1968 Overlander
https://www.airforums.com/attachment...ic34024_12.gif
man7sell is offline   Reply With Quote
Old 03-31-2011, 05:38 AM   #23
1995 28' Excella
Mobile , Alabama
Globe totter have good knees?
Old 03-31-2011, 05:56 AM   #24
1995 28' Excella
Mobile , Alabama
THIS ONE DOES NOT, FEMALE COUNTRY GIRL WITH CANCER, I AM 58 and tired of wasting money for rent! HUBBY HAS DEMENTIA AND HE WANTS RECLINERS IN AND SOFA OUT! OUR NEW CARPET WILL NOT STAY STRETCHED! 3 YRS old stain master! NOW WE BOTH NEED STABLE FLOOR!
DID YOU PUT CARPET PAD OR OTHER UNDER COVERING UNDER FLOOR 1ST AND DID YOU TREAT FLOOR ALSO?
Old 03-31-2011, 05:58 AM   #25
1995 28' Excella
Mobile , Alabama
WOULD OAK BE BETTER THAN BAMBOO? OUR BAMBOO IN POOL HOUSE IS SOFT AND SCRATCHES BAD!
Old 04-01-2011, 05:59 AM   #26
1969 31' Sovereign
Wolfe City , Texas
I chose the laminate flooring because the cork and wood flooring do scratch and dent easy and can stain. For my 32' Excella it will take about 4 boxes of laminate flooring.
Rita, I understand your concerns and health problems. I have congestive heart failure with 9 stints, degenerative joint disease with surgery on both shoulders and back, and have early stage Alzheimer's. I am doing my Airstream to fulfill a dream I have had since 1973, the first time I went in one. I bought it 4 weeks ago and am slowly getting started on the renovation. I wish you both the best in your remodel. Kelly
Sov1969 is offline   Reply With Quote
Old 04-01-2011, 06:03 AM   #27
1969 31' Sovereign
Wolfe City , Texas
I forgot - lol. Should I do sealer / treatment on the floor while I have the sub floor exposed? I can see the benefits of doing so but am concerned about the toxic effects it may have on the environment inside the trailer. Thanks, Kelly
Old 04-01-2011, 08:29 PM   #28
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Kellywood, look for a sealer that is water based. I don't think they seal as well, but health is a bigger concern.
Gene
Old 04-05-2011, 07:17 PM   #29
Emerson75's Avatar
1975 25' Tradewind
Hanover , Pennsylvania
Rot Doctor under laminate?
Has anyone coated their plywood with Rot Doctor while the plywood is exposed, prior to putting down their new laminate floor?
I've used Rot Doctor around certain areas which showed signs of, or were prone to moisture. I have quite a bit left, and I plan to put some Pergo down (which I was given over the winter from a relative) to replace the original carpet. I was considering coating the entire plywood floor while I have the carpet out, and prior to putting the Pergo down. I haven't contacted Rot Doctor to ask if there would be problems in doing so.
Eric, Stacey, Easton, Annabelle, Gretzky (boxer), & George Bailey (basset hound)
1975 Tradewind - Family owned and operated since 1975
2005 Chevy Tahoe Z71
Emerson75 is offline   Reply With Quote
Old 04-06-2011, 07:42 AM   #30
1969 31' Sovereign
Wolfe City , Texas
You might want to read this. It gives a good idea of how to apply the products as well as what other products are out there. Rot Repair -- Fixing Rotted Wood
Be sure to check out the "home brew" link. It is a very cost effective alternative especially for large areas.
Old 04-06-2011, 08:33 AM   #31
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Read the health warnings!
Be sure to read and follow Rot Doctor's procedures for protecting yourself during the use of their product. The warnings on their website look like it may have health risks if inhaled.
pergo, floor repair
Abby gets all the attention Lance M 1970 -1973 Ambassador 269 09-02-2022 04:58 PM
Abby gets some separation H Lance M Repairing/Replacing Floor &/or Frame 492 09-15-2020 03:02 PM
1977 airstream 33' sovereign land yacht pergo floor eBay Watch Airstreams on eBay 0 02-04-2011 12:00 PM
Bamboo Flooring Argosy22 Interior Restoration Forum 1 01-23-2011 08:41 PM
