You can buy a heavy duty saran wrap type of protection - used primarily by realty people when showing a house. It sticks to the carpet - kinda like a post-it pad, and can be replaced about once every week or two.
There is also a more permanent runner that you can get at Home Depot or any other big box hardware store - it's thickish clear plastic with little grabbers on the bottom. Used in stairways, etc to protect the carpet.
One problem with layering carpet on top of carpet is that the friction between the top layer and bottom can mess up the fibers on the bottom permanently.
Of course if you use a throw rug at the door and take off your shoes most of the dirt won't track in. Crocs are popular because they are kick-offs.
Paula
Today is a gift. That's why they call it "the present"
We are big proponents of kicking off shoes at the door, makes such a difference in what comes inside (dirt, pesticides, animal waste, bird droppings) that you really don't want to be barefoot in. We have been advised the same as Paula, in that you don't want anything on your carpet that moves as you walk on it, because it will permanently harm the underneath fibers. The cut-to-fit plastic runners with teeth on the bottom work very well on carpet, are heavy enough to be quite durable and wipe clean. You can also use those rubberish, mesh rug stabilizer mats under rugs and runners, available at WalMart, etc., which serve the same purpose and allow a more decorative runner.
I purchased some cheap 6+ feet long narrow runners at Wallmart. They are black and I love them. I have them over my tile floor. Easy to clean, take outside and scrub with soap and water and let dry in the sun. Also used such in my former Class A.
You may now want black with pet - I think they have other colors. They are rolled up in the store.
I guess we have a different take on what carpet is for—it's to walk on. Would you take out the carpet and put down a plastic floor? Vaccum frequently and the carpet should last longer and if the carpet is any good, it should last a long time. It's there to enjoy, not cover with a cheap runner.
We don't take our shoes off either—it's to live in, the outside world is dirty and some of it is coming inside. Of course, we have vinyl through most of the trailer (a plastic floor, but not as ugly as those plastic runners), so it's easier to keep clean, but it's not as nice as carpet or what we have in most of our house—tile.
Wow! Walmart has a great selection in store. There is an IKEA about 30 miles away and I saw on their website that they have runners too, but Walmart is so much closer. Thanks for the tip.
Karen & Jay
1987 Aistream 345
RTINCAN
WBCCI #3562
We use 2'x2' carpet tiles. I got mine free from a carpet vender that was going to throw away a box of samples. They sit on top of my marmolum floor. They are great because you can piece them together however you want, and they cover the main path through the a/s. Aso, if one is dirty you just pick it up and take it out side to beat against a tree, or toss if stained...
Hi Judy,
I found a nice pattern at walmart and purchased the non slip grids to put under them. It looks great. Photos up next week as I am almost done with cleaning the inside and the replacement curtains finally arrived from airstream.
Karen & Jay
1987 Aistream 345
RTINCAN
WBCCI #3562
