Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 12-02-2013, 05:46 PM   #1
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
Attaching Quarter Round???
I am looking for some ideas on how to mount my quarter round over my floating cork floor? My 2 ideas so far have been: and adhesive or small screws.
If I went the adhesive route, I would need something that sets up very quick and holds strong. There really isn't a way for me to hold the quater round in place other than by hand.
If I go the screw route, I was thinking something like #6 or #4 screws but then I have to drill holes everywhere...
Any ideas on type of adhesive?
Thanks!
Chris
crabbey1 is offline   Reply With Quote
Old 12-02-2013, 05:49 PM   #2
1994 30' Excella
Mississauga , Ontario
How about 3M double sided tape as used for trim on exterior of cars? I think it is red in colour and instant adhesion.
Al
Al and Jean
TAC ON-3
Old 12-02-2013, 05:52 PM   #3
crabbey1's Avatar
1976 Argosy 22
Images: 33
Not a bad idea. Can you pick that up at big box stores or do I need to go to a automotive place like Autozone?
Old 12-02-2013, 05:56 PM   #4
crabbey1's Avatar
1976 Argosy 22
Images: 33
Is this what you are refering to?
http://solutions.3m.com/wps/portal/3...cialtyVehicle/
Old 12-02-2013, 06:02 PM   #5
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
Why not pre-drilling the quarter round and using finishing nails? That with some filler that comes in various colored sticks to match your finish, should be just fine. Lots of different ways to skin a cat, (no offense to the cat lovers out there, just an old saying, no cruelty intended)
Dennis
1997 25' Safari
2012 Chevy Silverado HD 2500
Duramax/Allison
dirigible25 is offline   Reply With Quote
Old 12-02-2013, 06:04 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
This is the only place I use Silicone adhesive. An easy install, and allows float with clean follow up maintenance if required.
Old 12-02-2013, 06:09 PM   #7
crabbey1's Avatar
1976 Argosy 22
Images: 33
The surfaces that will be mounted to vary greatly...
Wallpaper on wood
Aluminum
Vinyl covered aluminum
Wood
I thought that we couldn't use the silicone on aluminum? Or does that only apply to bare aluminum? Painted or vinyl covered would be ok?
Old 12-02-2013, 06:57 PM   #8
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
For what you have in mind….it will work OK.
Old 12-02-2013, 08:06 PM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
First off, I would use base shoe instead of quarter round because it is smaller. I actually usedshoe and cut it down to make it smaller- 5/16 " thick instead of 7/16. I think it looks better. I used 3/4" wire brads with a brad nailer for wood. See my thread for photos- dan's 66 tradewind improvements.
Dan
Old 12-02-2013, 08:47 PM   #10
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Don't use screws - way too bulky and unsightly. I sort of agree with Dan, 18ga brads shot with an air gun, but why use 3/4"? you need to grab at least 3/8" minimum beyond the depth of the base shoe, preferably 1/2" or more for secure attachment. I have a finish carpenter friend who is a big fan of 2 sided tape, but only as a method to temporarily attach a difficult piece. I wouldn't install a finish piece using an adhesive unless it's the only way to get it to stay in place.
Just my 2c, and worth every penny.
DryFly is offline   Reply With Quote
Old 12-02-2013, 11:27 PM   #11
crabbey1's Avatar
1976 Argosy 22
Images: 33
I don't think wire brads will work. They need to go through the pine 1/4 round and hold into the aluminum.
I already bought, cut, stained and sealed the 1/2" quarter round so it is staying. Well check out the other stuff next time around.
I went to home depot and got the 3m double sided tape. I am going to give it a try. If it doesn't stay, I only lose $15. I will let you know how it goes.
1976 22' Airstream Argosy
Old 12-02-2013, 11:59 PM   #12
Double sided tape works well
0557 is offline   Reply With Quote
Old 12-03-2013, 12:15 AM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, if you are going to use double sided tape, only use the one with the red plastic protector with the gray/black tape; [automotive type] Do not use the one with the green protector with a white tape. [home type]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 12-03-2013, 06:52 AM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I used a brad nailer. Working great!
The tape will work.. It will capture the dust bunnies just fine.
Problem with tape.... It takes up space so you will always see a bit I of it when lining from above, if taped to side. You will red tape the whole length or things will get captured.
Or use tape after routing a shallow groove for it to sit in the shoe molding.
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-03-2013, 08:05 AM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I pre-drilled the wood trim and used very small screws. Seems to hold up fine, and its been two years
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-03-2013, 08:13 AM   #16
Ahem, yasss ...kaff-kaff
egad's Avatar
1969 27' Overlander
Bloomington , Indiana
You might try try trim screws, available at lowes, home depot, etc. Square drive is superior to phillips heads. Available in various colors and material, e.g. stainless steel, galvanized, etc. As others have said, shoe mold will flex easier than 1/4 round. Good luck!
Egad
egad is offline   Reply With Quote
