03-24-2010, 07:30 AM
1960 26' Overlander
Burnham
, Pennsylvania
Shock info needed!
I have a 1960 Tradewind with a leaf spring axle and I am having a hard time finding out what shocks are right for this application. It had shock because the mounts are there but no shocks, so I don't have an existing shock to match. Has anyone done a shock replacement on an old leaf spring axle or know the correct shock to use?
Tim
03-24-2010, 07:42 AM
1967 22' Safari
1960 Caravel
Edmonds
Tim
Hi Tim, If no one comes up with the answer before light(where I am). I will get the number off the replacements for the Caravel. I know they are Monroe and I got them locally at NAPA.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
03-24-2010, 08:50 AM
1967 22' Safari
1960 Caravel
Edmonds
This is what I put on the Caravel. Monroe 5752st. I had no issues with fit or performance.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
03-24-2010, 08:52 AM
Corona
Lee.
In all my years, I have yet to have the correct NAPA number.
Please post it so that we can others know that are not normally on this Forums.
Thanks.
03-24-2010, 08:58 AM
1967 22' Safari
1960 Caravel
Edmonds
Lee.
Thanks.
Sorry Andy, I don't have the NAPA number. The number is directly off the shock.
I did a quick web search and it looks like this shock can be found at most auto part stores.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
03-24-2010, 09:02 AM
1960 26' Overlander
Burnham
, Pennsylvania
Lee,
Thanks for the info. It is greatly appreciated!!
03-24-2010, 01:36 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
i just got off the phone with monroe. that 5732st shock application is for vertical use. they suggested looking in the steering stabilizer section of their spec. sheets to see if they make something that would work. if the shock has a metal sleeve in the end bushings, you'll need that info too.
http://www.monroe.com/catalog/docume...engthSheet.pdf
Ricky
03-24-2010, 02:05 PM
1967 22' Safari
1960 Caravel
Edmonds
This is a leaf spring axle and uses a vertical shock.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
03-24-2010, 02:30 PM
Try a Monroe 33033.
03-24-2010, 02:50 PM
1984 31' Excella
1976 Argosy 24
Olsburg
, Kansas
shocks, etc.
I don't know if this will help. If you take the shock off and measure the open length and closed length and have those dimensions, then what are the ends like, both eye hole or one with threads or both ends threaded, etc. Sometimes on older cars, you can look up in for Chevy, Ford, etc. shocks and find the length you need. Sometimes look at Summit Racing, etc for shocks also. If you have the dimensions and description the tech people might be able to help. Possibly a company that makes shocks might have a tech line for answers.
Good luck on what you are looking for.
03-24-2010, 07:16 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
sorry for my mistake but i hope the information will still be useful :-)
Ricky
06-17-2010, 01:41 PM
1960 24' Tradewind
Janesville
, Iowa
I just got off the phone with my Napa salesman and he found a cross referance to the 5752 number but not the 33033. He said the 5752 shock measures 12" extended and 8" compressed.
06-17-2010, 02:23 PM
Corona
shocks
The Airstream horizontal shock, extends from 9.5 inches to 14.5 inches.
However, it is too short to work with the "vertical shock" brackets.
It can be used, but you must cut the vertical bracket in half, overlap it and weld it back together, so that the stud to stud dimension does not exceed 14.5 inches, when that side of the trailer is jacked up.
But you must make sure that the rubber rods in the axle have not "solidified" which would restrict the wheel from dropping to it's maximum design.
06-17-2010, 09:53 PM
1967 22' Safari
1960 Caravel
Edmonds
Just to be clear... This thread is about a replacement shock for a leaf spring axle. No need to worry about rubber rods.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
06-26-2010, 02:21 PM
1960 24' Tradewind
Janesville
, Iowa
I just installed the 5752ST shocks. Turns out the measure 12 3/4" open and 8 1/2" closed. My old shocks measured 13" open and 8 5/8" closed. I think these will work great.
07-01-2010, 02:18 PM
Moderator dude
1966 26' Overlander
Phoenix
In addition all pre-1967 Air Stream trailer had vertical shocks.
Original poster has a 1960 Tradewind.
>>>>>>>>>>>Action
