I used POR-15's White Coat and I use the shower all the time. Has a glossy finish and is easy to keep clean.
Ditto
I haven't done the one in the Airstream...yet. But I have used it on a fiberglass tub at a beach house that is rental property. That was two years ago and is still looks good.
Aaron
WBCCI #XXXX AIR #2495
You might want to consider Awlgrip. It's a marine product. Expensive and should be professionally done but a fantastic product. The 2000 series can be applied and the imperfestions buffed out to a beautiful polished finish.
Awlgrip can be applied with a foam roller and then "tipped" with a brush to get near spray quality finish. I like the Awlgrip Polyester Urethane Topcoat because it resists "yellowing" as it ages. Good stuff!
2010 30' Classic
South of the river
Thanks for the replies.
I'm using Brightside since it is locally available while Awlgrip is not.
I don't believe I can use a two-part urethane without stripping the existing coating off the walls, which are a combination of aluminum, wood, and fiberglass. That would be an enormous job.
