Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 07-03-2007, 09:16 AM   #1
Naperville , Illinois
Need argosy window U trim
Does anyone know where I can find the plastic "u" shaped trim that goes around the curved windows in my Argosy where the window frame meets the inside wall? Mine are brittle and break when I try to clean them. Or has someone found a different way of replacing this trim? Appreciate any ideas. thanks!!
nodpete is offline   Reply With Quote
Old 07-03-2007, 09:22 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi nodpete -- Hope you're enjoying the Forums! You're going to make us look good with this question.
That item is called j-trim and some Airstream dealers stock it. For quick service and inexpensive postage I can recommend OASIS R.V. CENTER, INC. - Home in Tucson. They know Airstreams top to bottom and their parts department is excellent working with you over the phone. 1-800-658-5863
You'll need to remove and replace pop rivets to put in the new material but it's worth it -- it looks sharp! You'll have to snip the longer hidden backside with side cutters every inch or two to go around the curve by the windows.
5 meter Langford Nahanni
Old 07-03-2007, 01:50 PM   #3
Thanks Bob, I'll give them a call. Yes, I am enjoying this forum. I'm new to this stuff, but it's great to be able to ask all this expeirience on any problems that folks have.
Old 07-03-2007, 04:11 PM   #4
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
further info.
Airstream at JC has this trim also. We found it at our local big box home improvement store in various colors too.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
side front window for '74 Argosy dootsie Windows & Screens 2 10-23-2002 08:28 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
