Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 01-04-2010, 07:56 PM   #1
1976 31' Excella 500
Coal Center , Pennsylvania
How do I attach framework to walls?
I am not so much concerned about what I want as to how I want to attach wood to the walls. If I want to build a gaucho (and I'm using "I" very loosely) how does it become stable?
ubuckster is offline   Reply With Quote
Old 01-22-2011, 01:47 PM   #2
Viper2's Avatar
Jay , Maine
Id just screw it in myself or make a u-channel and pop rivet it up. slip would in channel then add screws and done. Just my 3 cents, since two doesnt work these days.lol
Viper2 is offline   Reply With Quote
Old 01-22-2011, 04:10 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
On mine they just ran the screw into the walls...just make sure they are short enough to NOT penetrate the outside skins. In some cases they did rivet an aluminum angle to the wall, and in some cases they even hit ribs. Then fastened the wood to the angle.
Aaron
WBCCI #XXXX AIR #2495
Old 01-24-2011, 04:49 AM   #4
Thanks for the information. I'm always leary about screwing anything into the walls but it makes sense especially after I removed a panel and saw the numerous ones left by the po.
How did you attach your wiring? vhord General Repair Forum 11 12-08-2008 02:44 PM
Attach Hitch to Bambi dsaxon22 Hitches, Couplers & Balls 8 06-17-2008 02:54 PM
How to attach photos? imeynstein 1974 - 1979 Sovereign 14 04-07-2004 08:54 AM
Skeleton Framework of Newer Airstreams hex Repairing/Replacing Floor &/or Frame 6 02-01-2003 08:05 AM
Airstream Framework & Skeleton hex Repairing/Replacing Floor &/or Frame 5 11-08-2002 06:09 PM
