Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 06-05-2007, 06:04 PM   #1
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
A trip in the Way-Back machine
Anybody remember Rocky and Bullwinkle? Moose and Squirrel? Boris and Natasha? The Professor and that little geek that always went with him on those voyages thru history?
Way back in September, 1972 when our camper was built, Airstream used the type of clip in the picture below to hold the electrical wiring in place between the outer shell and the inner skins (they grey one in the picture). These are great fasteners…until you start taking things apart and the plastic disintegrates. The adhesive on the back of these things still sticks to the aluminum after 35 years, the basic problem is that the plastic becomes brittle after all those years.
So the question is, what have y’all used as a replacement for these things?
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 06-05-2007, 06:19 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I've seen the exact clips here. McMaster-Carr
on page 1436
Old 06-05-2007, 06:26 PM   #3
Naples , Florida
Perhaps you would like a little larger selection?
Find these at Waytek Wire : Electrical Wiring Supplies & Industrial Products. go to the products page and scroll to clamps and select 'adhesive backed clamps'.
They are wholesale only with significant quantities required, but they carry only the BEST!
25323 ADHESIVE BACKED CLAMP 1/2" MAX
WIRE BUNDLE
EA0.3452 25328 ADHESIVE BACKED CLAMP 1/2" MAX
WIRE BUNDLE
EA0.1048 25387 ADHESIVE BACKED CLAMP 1/2" MAX
WIRE BUNDLE
EA0.2403 25321 ADHESIVE BACKED CLAMP 1/4" MAX
WIRE BUNDLE
EA0.2578 25327 ADHESIVE BACKED CLAMP 1/4" MAX
WIRE BUNDLE
EA0.0786 25385 ADHESIVE BACKED CLAMP 1/4" MAX
WIRE BUNDLE
EA0.1770 25391 ADHESIVE BACKED CLAMP 1/4" MAX
WIRE BUNDLE
EA0.1027 25330 ADHESIVE BACKED CLAMP 1" MAX
WIRE BUNDLE
EA0.3714 25320 ADHESIVE BACKED CLAMP 3/16 MAX
WIRE BUNDLE
EA0.2075 25384 ADHESIVE BACKED CLAMP 3/16 MAX
WIRE BUNDLE
EA0.1311
lewster
Old 06-05-2007, 07:56 PM   #4
Well, here’s the deal. I purchased these little guys (pictured below) back in February and reinstalled all the wiring. As soon as the weather warmed up, the rascals started to fail. These dang things were supposed to be good to 165 degrees. The basic problem is that the sticky “feet” attached to the fastener remains attached to the aluminum, but pulls away from the fastener. I’ve tried several ways to attach the fasteners to the aluminum directly (glue, epoxy and so on) and nothing seems to work.
Has anybody actually used any of the fasteners listed above with any success?
www.nesa.org
Air No. 6427
Old 06-05-2007, 08:39 PM   #5
Condoluminum's Avatar
2016 25' Flying Cloud
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Mr. Peabody and Sherman
Just to close loop, the Professor and inventor of Wayback Machine was Mr. Peabody (a dog..), and his young geeky companion was his boy, Sherman...
Rocky and Bullwinkle were great TV...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 06-05-2007, 08:42 PM   #6
Retired.
. , At Large
Have you thought of velcro?
Old 06-05-2007, 08:44 PM   #7
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Go low tech - use duct tape.......
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 06-05-2007, 10:20 PM   #8
Aerowood's Avatar
Arvada , Colorado
I,ve used these at work, expensive but the best I've ever used: Click Bond, Inc.
Old 06-06-2007, 08:41 AM   #9
Thanks for the tips, guys. I'll bet one of these will work.
Clancy--I assume that the wires should not be taped down in all places because they need to flex with the camper.
Terry--I'm using velcro in some places already, but it can't be used every place because you still need to be able to fasten it down.
All of this is based on the idea that the wires need to be held loosly in place. In other words, there needs to be some minor movement allowed in the wires to account for flexing of the camper, but they need to be tied down in order to avoid the insulation being rubbed off the wire by the walls while rolling down the road.
Thanks again everybody.
www.nesa.org
Air No. 6427
Old 06-06-2007, 06:49 PM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
jim
just save your old clips if they don't break and renew the adheasive by using 3M double stick tape for body mouldings.
any good body shop should have some.
john
you call them ferrets, i call them weasels.
Old 06-06-2007, 08:26 PM   #11
Images: 59
Use the original factory method, from before Rocky's era (1959).
2003 International AS Pahaska 2002 - 2005 International 149 10-01-2017 06:38 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
Trans-continental trip winner On The Road... 6 10-27-2002 08:49 AM
Very interesting story/ back pack FrankR On The Road... 2 08-31-2002 08:29 PM
Motorhome Rally Post-Rally Chatter ViewRVs Airstream Motorhome Forums 12 04-14-2002 12:30 PM
