10-28-2013, 08:43 AM
2014 25' FB Eddie Bauer
Knoxville
, Tennessee
Winterizing
I am thinking about leaving my coach plugged in and the heat on all winter in the carport that's attached to the house. I will also be keeping water in the tanks to use the unit. I would appreciate any advise to keep from harming the unit in any way. I live in East Tennessee and it does get below freezing throughout the winter.
10-28-2013, 08:59 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Pay special attention that you don't cook your batteries. Being plugged in all the time with your converter charging the batteries all the time will fry your batteries in no time.
10-28-2013, 09:12 AM
2004 30' Classic Slideout
Fenton
, Missouri
Yep if you stay plugged in all the time, your batteries will require frequent checks since your converter will cause the liquid to bubble and evaporate. I've exposed the plates and damaged the batteries by not checking frequently.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
10-28-2013, 09:31 AM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Or, Replace Your Converter
As soon as I got our current Airstream, I replaced the converter-charger with an Iota DLS-55 with a smart charger. It stayed plugged in for the last two winters since we had it parked in an RV resort here in Mesa, and the batteries did fine. This winter, since we won't be living in the Airstream, I removed the batteries and keep them in my garage on a Battery Minder smart charger.
You must top off the battery electrolyte with distilled water at least twice a year, but this will always be the case proportionate to how much you use your Airstream.
P.S. In every Airstream I have owned, I have replaced the converter as soon as I buy it. I once insisted on using Progessive Dynamics Inteli-Power converters. This time I switched to an Iota DLS-55 in my current Airstream, and I am very pleased.
Hope this helps.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
10-28-2013, 09:37 AM
1974 Argosy 26
Morrill
, Nebraska
If you are concerned about the batteries being overcharged and have a modern converter. Just disconnect the batteries and tape off the leads. I always remove the battery and just use the converter when plugged in at home. Haven't had a problem in 4 years.
10-28-2013, 01:27 PM
Knoxville
, Tennessee
Can I just put the AS in "store" mode while plugged in? It is my understanding that the batteries will not be charging in store mode. Am I correct or am I missing something? What if you live in your AS full time?
10-28-2013, 01:47 PM
Albuquerque
, New Mexico
I believe that the 2014 is wired to charge batteries in the "Store Mode."
You can always disconnect the batteries if that is the case.
But, they will discharge in 4-8 weeks depending on their condition (if they are lead-acid, flooded batteries).
Otherwise, I like your plan to keep heat on the trailer with electric space heaters. Be sure to open the cabinets.
I would remove the batteries and maintain them in the garage on a Battery Minder as I do.
10-28-2013, 02:00 PM
1976 31' Sovereign
Oswego
Since 1991, I never winterize my 1976 A.S. just dump gray & black tanks pump what water out as in 1976 A.S. did not provide method to empty potable tank, back into heated machine shed plug into 110, do not disconect batts. or any thing else furnace off, lock doors, forget till next spring, never ever had prob. batts. or any thing else. I also keep P.U. tractors etc. in shed so I can justify heating.
10-28-2013, 02:06 PM
Albuquerque
, New Mexico
Sounds like you are keeping a charge on the batteries with the converter-charger. Correct?
10-28-2013, 05:01 PM
1976 31' Sovereign
Oswego
converter charger
Yes, never fried batts. since 1962 [first A.S.]. converter 1n 1976 crashed replaced, never had prob. w/batts. never used batt. tender etc. avg. batt. life 6 yrs. Also keep plugged in except on road or boondocking.
10-28-2013, 05:08 PM
Albuquerque
, New Mexico
Conucur
I charge all winter as well.
For the last two winters, they stayed in the Airstream.
This year they came out of the Airstream and into the garage on the Battery Minder because the Airstream is in a storage lot.
My experience matches yours except my average battery life is closer to 5 years.
10-28-2013, 07:56 PM
1999 34' Excella
Hillsboro
What is "winter"??? Hardly can comprehend here in Central Texas..but, I have experienced -20F and 60MPH wind...and have seen what it does to man made things. We are sorta praying for a mild winter here again in Central Texas...any freeze we can handle with inboard heat for a day.
Peace and Blessings..
Channing
WBCCI# 30676
10-28-2013, 09:01 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
Are you heating it with the furnace or a space heater?
If the furnace, that will heat the fresh water tank and the other tanks, but will use a lot of propane. You might need to get a larger propane tank. The furnace fan will keep the batteries from getting too charged, but you should check them frequently and add water when necessary.
If you use a space heater, the water tanks get no heat and can freeze unless you seal; seal around the trailer and provide some heat from underneath the tanks.
If the temp gets below 20˚, keep any eye on the tanks as the furnace can only do so much. You can do as you would with a space heater—seal around the bottom of the trailer and possibly supplement with heat from below. If you keep water connected, you will either have to remove the hose when the temp goes below freezing, or get a heated hose. If you keep water connected to city water and keep the fresh water tank empty, you will still have to heat the black and grey tanks.
Airstreams are not really meant for winter use. The insulation is very thin and the metal and glass dissipates heat fast. It can and is done, but not without some challenges. There are a number of threads about winter living—check them out.
Gene
Gene
11-03-2013, 12:17 AM
Salem
, Oregon
Hi, I bought this at Camping World today for about $4.00 and will possibly need to use it some day. I believe that the hose will be too short. I can fix that.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
11-03-2013, 09:40 AM
Albuquerque
, New Mexico
That's What I Use
When I sell an Airstream, it doesn't convey. The one I have is solid brass. It has helped winterize four different Airstreams through the years.
11-06-2013, 06:15 PM
Master of Universe
Grand Junction
Bob,
I've used one for years, though I didn't pay only $4 for it. The hose should be long enough to fit into the antifreeze bottle. Glad to see winters are getting colder in southern Cal.
You can also get at CW an adapter for your compressor to screw into the city water inlet to blow out the rest of the water after you drain the system.
Gene
Gene
11-06-2013, 06:23 PM
Fenton
, Missouri
I can't put in a valve assembly due to the fact that the pump assembly and assorted piping is right next to a wheel well. Repositioning the the pump also means having to redo some piping. Bottom line I bought the hose only. Since the fresh water inlet is a hand tight nut, it's just a matter of unscrewing that and screwing in the hose and flipping on the pump.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
11-07-2013, 11:10 AM
1998 31' Excella 1000
Bellevue
, Nebraska
Bob: You're right the hose is too short. You'd think they would have recognized that after reading or hearing the same complaint forever. Oh well! If you have a shower hose connected to the telephone type shower head, it is the same thread size and has the o rings already in place. It will connect directly to the input side of the pump. Just stick the other end into the anti freeze bottle and away you go. I used mine, worked great. Ron
11-07-2013, 02:48 PM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
Since I've not winterized our current trailer, I had a couple of questions for the Techs at Jackson Center.
And they basically said to save some effort and forget adding antifreeze to the PEX lines.
Essentially I was told that blowing the lines, draining the water heater, and adding antifreeze to the p traps, gray and black tanks (a cup or so in each) would be sufficient. Then turn the fresh water pump on for about 10 seconds to distribute what water was in it.
I'm thinking about doing what they've told me twice. ;-)
11-07-2013, 03:24 PM
Holly Lake Ranch
That's good to know about the water pump, I winterized Saturday using the exact same method but did not think about water being left in the pump. but used the same method last year and it worked fine, although I forgot to drain the filter under the sink and it froze and broke. Still haven't been able to get the model number for that Moen filter from JC. They wanted me to send a photo of what I was talking about. I don't think it was an after market add on.
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
