Old 10-22-2011, 06:07 PM   #15
tkowalyk's Avatar
2006 25' Safari
North Wales , Pennsylvania
Images: 11
We always use a socket to get it off. If you have damaged it, they are inexpensive to replace ($1.50 to $4.00 depending on where you buy it).
Here is a link from Amazon that has a good picture:
Amazon.com: ATWOOD MOBILE PRODUCTS 91857 DRAIN PLUG 1/2"(2) PLASTIC
This link will help you in determining if the part will fit your your water heater, or just bring the plug down to the local RV dealer:
Atwood 91857 Drain Plug Half Inch 2per PK Water Heater Parts Trailer Camper RV
Hope this helps.
Tom & Lori
2006 Safari 25SS
2007 Dodge Durango -- 5.7 Hemi
tkowalyk is offline   Reply With Quote
Old 10-22-2011, 06:10 PM   #16
MStewart's Avatar
2011 22' Sport
New Market , Virginia
Perfect! And I was more worried about it than the still bleeding knuckles.
Thanks much.
MStewart is offline   Reply With Quote
Old 10-22-2011, 06:36 PM   #17
tkowalyk's Avatar
2006 25' Safari
Images: 11
MStewart,
Good luck with the new rig!
We will still do a couple of fall "dry" camping trips this fall. We will go to a RV Resort in Gettysburg that has keeps its facilities open, and maybe a State Park that is close to home.
We bring along a 5 gallon water container, and will use the galley sink. We will drain the grey water tank and pour some antifreeze down the drain again.
Another pointer -- we have found that a small ceramic heater does a fantastic job of keeping the trailer nice and toasty. We bought this one earlier this year, and used it a couple of weeks ago at the Penwood Fall Colors Rally:
Amazon.com: Lasko 754200 Ceramic Heater with Adjustable Thermostat: Home & Garden
Tom & Lori
2006 Safari 25SS
Old 10-23-2011, 06:09 PM   #18
2010 27' FB International
Birmingham , Michigan
Best bet is a crescent wrench on the water heater plug. If you have destroyed the nylon head on the plug...pick up a new one. Also, you don't have to tighten the plug quite that much. Don't forget to close the hot and cold inlet/outlet at the water heater and open the bypass BEFORE you add the antifreeze. That stuff will ruin your water heater. Also, if you have blown each and every line out with air AND emptied the water pump COMPLETELY AND drained all your holding tanks...you don't really need to add antifreeze. The best way to empty your pump? Unscrew the inlet line and the outlet line from the pump. Now, blow air into the inlet side slowly until all the water is out of the pump. It will exit at the outlet line from the pump. After you do this...turn on the pump for just long enough to hear that there is no more "gurgling" water sound.
Lastly, add the antifreeze to each drain (shower, sinks, toilet) so it replaces the pure water in each of the pea traps. Make sure there is an inch or so in the toilet...on top of the flush flapper. That will keep it lubricated.
Just for the record...while I do store my unit indoors...unheated...I have never removed the TV or radio and it does just fine. Be sure to take the batteries home and store them in a cool, dry location. Don't store the directly on a cement floor. Just put something under them...rubber matt...couple layers of carpet...etc. Put a trickle charger on them.
Note: I always take a picture of the wiring to the battery before I disconnect everything. It's amazing how much you WON'T remember following a long winter.
Ok...I've talked enough. Good luck. Happy Airstream'n.
Aquabud is offline   Reply With Quote
Old 10-25-2011, 12:13 PM   #19
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
Water Heater Drain Wrench
I use a long handled 7/8" box wrench. It is long enough to clear the metal shield. I have a '97 25' Safari. My water pump is below the counter top in the galley, and right next to the heater. Pulling the drawers out give me room to stick my head in and see what is going on. I did have to back off the mounting screws to the pump to add the fitting to suction side of the pump to be able to draw in the RV anti-freeze. I live in the Pacific Northwest, in Washington state, so not taking chances without the pink stuff.
dirigible25 is offline   Reply With Quote
Old 10-25-2011, 02:16 PM   #20
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
On "most" water heater drain plugs I've seen, you can use a socket and extension to remove it ... there's a clear path to do this ... so you don't have to try to use a wrench or channel locks, etc. and risk either knuckles or the plug itself. Get down low and look up at the plug and I'll bet you will see the path to use a socket.
AirsDream is offline   Reply With Quote
Old 10-26-2011, 06:37 AM   #21
MStewart's Avatar
2011 22' Sport
Thanks all. Was using a crescent wrench but obviously not very well. The plug was quite resistant to being turned. Got a new plug and socket with extension. Next fall hopefully knuckles will not get mangled. Almost healed now.
Old 10-26-2011, 09:34 AM   #22
CrawfordGene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
I have considered replacing the plastic water heater plug with a metal one or valve that I just have to open or close. Still haven't done it, but it is an alternative. So far I have used channel locks to remove or tighten it and am slowly chewing it up, but my knuckles are still intact.
Gene
CrawfordGene is offline   Reply With Quote
Question on Air Compressor Oil in fresh water lines myropa Plumbing - Systems & Fixtures 7 10-17-2011 04:32 PM
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
Land Yacht Dash Air DonaldW Land Yacht/Legacy Motorhomes 25 07-21-2011 07:48 PM
Air compressor silverdream2 Classic Motorhomes 9 06-22-2011 10:29 PM
Air horns on 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-25-2011 07:49 AM
