Agree with Gamehawkers cure for bird invasions. It's been used before.
Another possible issue is mud dauber wasps and other insects getting inside the shroud. 1/4 inch hardware cloth will not keep them out very well.
Some on the forum have used aluminum window screen epoxied into the air openings. The downside is that it gets dusty and dirty and eventually restricts air flow. Then it becomes a pain in the butt to clean it regularly.
If you are not having issues other than birds, the 1/4 inch mesh hardware cloth is the best solution. It's always a good idea to pull the shroud as part of preventative maintenance each season to inspect the interior of the AC unit, check for bug nests, and lubricate and clean motors and fins as needed...
