Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 01-19-2009, 12:01 PM   #1
finalcutjoe's Avatar
Profile:  2008 30' Classic S/O
Dearborn , Michigan
Air Compressor on generator?
I'm having a heck of a time finding the electrical specs on these things... I can't even find numbers on my Campbell Hausfeld sitting in my garage-
What I'm looking for is a portable model, with at least 2GAL capacity, that my YAMAHA 2400 will run... I've been told compressors tend to draw monster loads on start-up
Any ideas?
Without knowing the motors efficiency coefficient- is there anyway to derive watts/amps from HP?
finalcutjoe is offline   Reply With Quote
Old 01-19-2009, 12:04 PM   #2
cameront120's Avatar
Profile:  1972 25' Tradewind
I don't know if this helps, but the framers who were working on my house used a very large compressor - I'm guessing around 50 gallon. All of my temporary power outlets are 15 Amp and they were able to operate their compressor with no problems.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 01-19-2009, 01:21 PM   #3
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 16
I just looked at my Porter-Cable 6 gallon pancake compressor and it's listed at 10 amps. That shouldn't be a problem. But if you really need to know, I'll haul out the Yamaha and test it.
Old 01-19-2009, 05:52 PM   #4
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Another alternative could be what Jeepers use. Because they deflate their tires for rock crawling some adapt an old auto AC compressor to reinflate the tires. Adapt by mounting the compressor in the engine compartment to run off of a 'fan' belt.
Neil and Lynn Holman
FreshAir #12407
Avatar;
Our Rig
Sept 2009
1966 Trade Wind
455 cid
Old 01-20-2009, 12:19 AM   #5
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Hi, I have a home model air compressor [2.5 H.P. / 120 Volts / 15.0 Amps] with about a twenty gallon tank and my Yamaha 2400 won't start it. [Yamaha 2400 rated at 16.7 amps max]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 01-20-2009, 06:06 AM   #6
Dearborn , Michigan
this is sorta what I had in mind...
Air Compressor Installation
Old 11-06-2009, 10:38 AM   #7
binkers's Avatar
Profile:  1993 34' Excella
Durango , Colorado
Did you ever find what you are looking for? I'm trying to find the same type of compressor as in the last image...a tankless, adjustable output for my airstream. Any recommendations? Thanks.
binkers is offline   Reply With Quote
Old 11-06-2009, 10:48 AM   #8
Dearborn , Michigan
I ended up buying a tiny 1gallon 'powermate' on sale for $48 from K-Mart. Small enough to fit in trailer trunk. (No specs on the box, "100PSI working pressure" whatever that means, took me 3x as long to blow-out the lines/waterheater). EF2400 didn't flinch at all running it.
Old 11-06-2009, 03:37 PM   #9
Alwhisman's Avatar
Profile:  1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 57
Send a message via Yahoo to Alwhisman
I run my 40 and 60 gallon 4 and 5 hp compressors with my 3500w generator, along with circular, miter and table saws. You should be able to run any 2 gal compressor with a 2400. Stay with a name brand like dewalt or porter cable. Some of the less known brands have higher startup loads (I had one).
I'll go out and look at mine and post what they are rated at...
Al
Alwhisman is offline   Reply With Quote
Old 11-06-2009, 04:08 PM   #10
Alwhisman's Avatar
Dayton , Texas
Images: 57
My Dewalt trim compressor (1Gallon) is rated at 1560 watts. (amps x voltage = watts roughly)
You should be okay with any small trim compressor. Just ask if it will run from a 20 amp outlet....
20a outlet at 120v is rated at 2400 watts max....
Look for a compressor with a smaller motor. Bigger the motor the more amps it takes (more watts). Bigger motor means quicker recovery, smaller motor just takes a little longer (runs longer)..my dewalt is .6 hp
Al
Old 11-06-2009, 06:13 PM   #11
Profile:  1977 29' Ambassador
Brandon , Mississippi
Just as some additional info...
My Honda 2000 will run a 2hp Campbell pancake version but WONT run a 2hp Horrible Freight unit that I bought.
Well, It will RUN it but only if ya dump all of the pressure from the tank before you try to fire it up.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
'Epiphany' the 29' Airstream and a honkin' long 34' named AlumaTherapy
Old 11-06-2009, 08:14 PM   #12
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Any ideas?
I have run my portable 2 gallon CH compressor off my Honda 2000. Eco throttle off.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 11-06-2009, 08:28 PM   #13
Alwhisman's Avatar
Dayton , Texas
Images: 57
This one will have a lower amp draw (smaller motor) 2.0 amp
FP209599DI - Campbell Hausfeld 2-Gallon Inflation and Fastening Air Compressor with Nailer and Accessory Kit
Old 11-06-2009, 08:39 PM   #14
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i have one from Craftsman that is like this one.
CAMPBELL HAUSFELD PORTABLE AIR COMPRESSOR KIT FP2004 CAMPBELL HAUSFELD
you'll need a tank if you want to blow out the water lines properly. the pressure regulator isn't exact.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
richinny is online now   Reply With Quote
air compressor wanderingeye Mechanics Corner - Engines, Transmission & More... 3 01-27-2006 08:47 AM
Air compressor for AS... crazylev General Repair Forum 4 05-11-2004 08:41 PM
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 01:58 PM
Air compressor ALANSD Airstream Motorhome Forums 15 01-02-2004 05:18 PM
Air compressor Craig Winterizing, Storage, Carports & Covers 4 11-07-2002 09:21 AM
