Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 07-20-2009, 12:56 PM   #1
Profile:  2004 16' International CCD
Scituate , Massachusetts
power jack keeps blowing fuse?
My 2004 International CCD came wired with a Barker Mfg. Hi-Power 3000 jack. Each time I try to raise it the fuse blows. The light works (prior to the fuse going) and the battery is fully charged. I'm really hoping someone can offer a repair suggestion or at least tell me where I might find the hand crank. Thanks!
jlemmons is offline   Reply With Quote
Old 07-20-2009, 01:53 PM   #2
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
My Ultra-Fab kept doing the same when first installed. Taking it back to the installer revealed a short in the wiring where it wasn't connected to the trailer battery properly. Can't help with the hand crank, though. It could be an actual crank you fit onto the top or it could be an attachmen used with a drill to work the jack.
BTW, welcome to the forums. Hopefully someone that knows about the manual crank will chime in.
TRAVELING WITH ELVIS
LIFE WITH A 1956 SOVEREIGN OF THE ROAD
• • • Aluminocentricity • • •
WBCCI# 14674, Washington DC Unit
Sugarfoot is offline   Reply With Quote
Old 07-20-2009, 02:05 PM   #3
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
There's an interesting note on the first page of the installation instructions - regarding proper grounding - that may help you.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 07-20-2009, 02:45 PM   #4
pilgrim's Avatar
Profile:  2007 25' International CCD
Sugar Grove , Ohio
Our first couple of times out with our new 25' blew the same fuses, again and again. Since we were just starting (learning) we discovered we were running the jack up way too high a couple of times. Other times we started running the jack up while we
were still lugged into the TV or into the land power. Once we started making sure we
were unattached to any other power source (land or TV) we've not blown another fuse. Coincidence.....I think not! Maybe it'll work for you. Good luck. You'll learn these forums are a wealth of information - some better than others. But well worth checking on. Best wishes for happy 'streamin.
__________________________________
2007 25' Airstream International SS OB
2004 Nissan Armada
Equalizer hitch
Prodigy brake control
"It's better to keep your mouth shut and thought a fool
Than to open it and remove all doubt."
pilgrim is offline   Reply With Quote
Old 07-20-2009, 03:51 PM   #5
Profile:  2008 28' Safari SE
winter garden , Florida
my 09 safari was blowing fuses about two weeks ago, same thing as above, still connected to tow vehicle while jacking. Have not blown a fuse since. If you have the same setup as me you have to remove the power unit from the top of the jack to get to the manual crank, hopefully you can find your hand crank.
bob34787 is offline   Reply With Quote
Old 07-20-2009, 04:02 PM   #6
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Being connected the a shore line or the TV should not effect the fuse capacity of the jack. Running the jack to it's limits should not effect the fuse. These jacks have an end switch and if adjusted correctly will just CLICK as the jack reaches the limit. If the fuse blows at the limit it has not been adjusted correctly.
First question. What size fuse are you blowing? Second question does the fuse blow while going up and down and before the limit or just up before the limit.
Need this info to give an indication of what to look for.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 08-01-2009, 11:38 AM   #7
Profile:  2008 25' Safari FB SE
Crawford , Colorado
I've had two instances of the jack blowing fuses. The first time was when I had been constantly raising and lowering it to adjust the Equalizer WD hitch. I figured (hoped) I had been using it too much on a hot day.
The second time was a few days ago when we were camping and had a site on a slope. To raise the trailer enough to make sure we could level it also raised the truck off the suspension. That's when the fuse blew. The jack is rated at 3,450 lbs. and was possibly exceeding it's capacity.
Luckily I had another fuse.
It seems to me these jacks are not strong enough for the situations they may encounter—raising the trailer and truck towards the top of the jack's travel. In some situations, just to get the WD bars on or off, the tongue has to be raised as far as it can go. Now each time I raise it I am worried it will blow a fuse, or worse, just quit.
Gene
CrawfordGene is offline   Reply With Quote
barker, crank, fuse, hi-power, jack
12 volt inline fuse stops power??? tinbender Vintage Kin 6 07-09-2008 05:37 AM
Fuse #1 keeps blowing Z33 Electrical - Systems, Generators, Batteries & Solar 12 12-16-2006 09:43 AM
Parking light fuse blowing andyfuson Tow Vehicles 7 07-26-2006 06:54 PM
Brake Light fuse keeps blowing BW_LandYacht36MH Land Yacht/Legacy Motorhomes 3 08-25-2005 01:25 PM
What fuse for the front jack qqq Jacks, Stabilizers, Lifting and Leveling 11 07-25-2003 02:15 PM
