Been thinking about changing out the manual tongue jack on our 71 Safari for an electric one. Most that I have looked at have a 2" post. Will that size jack fit on our trailer? Any brand the best to consider?
Dan
Should. The hole in the hitch is a pretty standard size. Make sure it has a gusset plate on the bottom of the A-frame that the jack will also pass though. That does add quite a bit to the suport the jack has.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
Does anyone know where I could find the crank that is used to operate the jack in the event the gears or motor take a dump? The book I have shows a pic of one. Looks like the gear box/motor is removed and the handle of the crank is inserted in the tube. Looked pretty cool. Wish I had one. My jack is factory Airstream.
Well, the weather is getting warmer here on the east coast. Time to start fixing up our "new to us" '79 Soverign. While looking for answers to my jack problems, I seem to have stumbled on an answer for both of us.
It took me a bit of time, but I finally found the H&H Manufacturing site, who makes the jack on my AS and is very simular to your description.
To the point, the handle is about $24.00 and the site is here . The manual and parts list is also on this site.
I hope this helps someone other then just me, now if I can just figure out how to get the jack unjamed.
Not to bitch and moan too much but our AS just came back from a jack repair. It timed it's demise in a non-typical manner by dying as it was being left off for other service at the dealer. A crank would have been a blessing if it had failed on the road. As it were the item going bad is a limiter. This is a small switch which tells the lift to stop at the maximum of it's reach. The jack would lower but not rise. A quick fix for a dealer but not if your unable to get unhitched. I now carry a spare scissor jack to lift the tounge if it happens in a more remote area.
Is that what that is. I initially tried that as the stabilizer crank and was lost as to how it worked. Then I found the correct crank for the back but was lost as to why I had the other one. Still learning obviously.
I finally got the jack out of the coupler. I had to grind off the bolts as they were so rusted. As it turns out, the bolts were the most solid part of the coupler/jack mount. The jack exterior contiues through the top of the coupler to just past the lower bracing mentioned a few posts ago. Well, that exterior tube had rusted away, allowing the inner tube, the one that pushes down to make the tongue go up to break free and sit askew. Long story short, I was able to get someone to weld a new lower tube, salvaging the end with the guide. We also welded new plates on the top and bottom of the coupler as that had all rusted through.
The moral? Check the 'inside' of the coupler for rust, clean and paint as required. I got lucky and was able to save the jack which to replace is about $325.00. If the PO's had done a bit of PM, then this would not have been an issue. And in truth, the rest of the TT looks in good shape so far.
Hi all: We have a 2006 Safari SE 28 footer, with the electric jack. If this unit should fail, how does one crank up the trailer manually. I see know obvious means to accomplish this, nor any tools provided for such a purpose. I know there must be something I am not seeing.
Hi all: We have a 2006 Safari SE 28 footer, with the electric jack. If this unit should fail, how does one crank up the trailer manually. I see no obvious means to accomplish this, nor any tools provided for such a purpose. I know there must be something I am not seeing.
Thanks in advance.
Robert and Sherry
Check your manual. The emergency procedure should be in there. There should be a small crank supplied along wirh all the small items that come in the trailer when it is delivered. if you don't have the crank, a suitable-sized ratchet and socket will do the trick.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Thanks Pahaska: So I did the obvious re: the manual, and now know the proper use of the tiny Allen wrench provided, and the emergency handle. Sorry I was lazy and did not check the manual first before asking the board.
