So I am trying to get the leaks stopped so I can start re assembly. I have these pesky leaks that I was trying to track down it appears they all come from the same issue. take a look at the image
http://2.bp.blogspot.com/-_yn6v2dbWe...leak+image.jpg
There was an old skin repair where they layered new skin over the old skin. from mid seam up to the zip D awning. it runs from above the door all the way back to the rear end cap. I have removed all the olympic rivets and replaced them with Buck rivets in hopes that this would stop the leaks but it did not. so now I am wondering what sealant would be best to use to stop these leaks.
I have available trempro 635 (vulkem)
parabond
I just did some reading about Captain Trollies creeping crack cure and it sounds interesting.
should I use a combo? Also what is the life expectancy of these products? how often do they need to be removed and re done?
