What is this hole on my street side front exterior?
In not sure where to post this, mainly because I am not sure what this is. But it's causing a leak so I figure here would be as good a place as any.
This hole has some sort of rubber piece that sticks onto the outside shell if my 1977 Tradewind. It has two wires connected to it that I can see from inside of the hole.
On the interior this is where my radio sits...so my best guess is that this has something to do with the antenna? But from the pictures I've seen the radio antenna sits on the front of the trailer frame so I'm not sure.
There was originally a plastic cover over this rubber piece that covered the hole entirely. But that plastic piece has disintegrated and is no longer covering the hole.
The hole itself is towards the front of the camper on the street side right under the front corner of the window.
What is this piece? Depending on what it is I will either replace it or just put a piece of aluminum on top and rivet it into place and then seal it up. Thanks!
