Old 03-14-2012, 11:21 AM   #1
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
TV antenna sealing
Hello all.
The PO admitted to driving off once with the TV antenna raised. I'm on the roof now doing the whole reseal thing, and the TV antenna base is bad. Much of the caulk was torn loose. I've removed what caulk remained. So, now for my question: should I just glob caulk all over it -or- should I lift the antenna bracket and put new sealant under it, too? AND, if you think I should reseal underneath, should I use some Sikaflex 221 under there or some grey butyl tape? (My gut felling is the butyl would deform less, and be less likely to squish out when I tighten the screws back.)
All kids are gifted; some just open their packages earlier than others. - Michael Carr
JazzDad is offline   Reply With Quote
Old 03-15-2012, 10:50 AM   #2
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
OK.
With more time I was able to find this: http://manuals.solidsignal.com/www-s...000%20TECH.PDF
Step 7.
Old 03-15-2012, 03:36 PM   #3
2004 16' International CCD
Orem , Utah
I used sikaflex 221 in white
Very tacky stuff almost like liquid nails, works pretty dam good.
starcraft is offline   Reply With Quote
Old 07-20-2012, 05:35 AM   #4
r carl's Avatar
Lin , Ne
I used gray vulkem 116 from Fastenal, looks great a year later.
replacing Sony 19" TV, how to remove the power cord? altamont Audio, Video & TV 5 03-16-2012 09:06 AM
Finally, A TV that costs as much as an AS! Denis4x4 Tow Vehicles 8 03-15-2012 03:14 PM
cable tv on vancouver island? charmadillo Audio, Video & TV 0 03-13-2012 10:53 PM
Skyliner antenna rebuild Flynavy Audio, Video & TV 17 03-12-2012 01:46 PM
TV Cable? shrimptank 1969 - 1973 Safari 4 03-11-2012 09:20 PM
