Old 10-16-2004, 10:51 PM   #1
mcneon's Avatar
Pressure Method of Leak Detection
I've read on other motorhome sites about a blower method of water leak detection. As I understand it, you hook a fairly powerful and high-volume air source to a window of your trailer or motorhome, seal up all the openings as well as you can, and check for leaks by applying a soapy solution to suspect areas. Apparently it doesn't take a very high pressure differential or a very big leak to blow bubbles.
Has anyone on the forum ever tried this on an Airstream? I have an annoying intermittent leak near my MH doorframe, and this sounds like a very good way to find it. I'm wondering what kind of blower is adequate but doesn't cost a fortune, and how you might easily attach it to a window opening.
Bob McKeown
mcneon is offline   Reply With Quote
Old 10-17-2004, 05:19 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have actually seen one
Bob,
The test unit in question is a pretty decent sized piece of equipment. The one I saw took air in from the roof vent and pressurized the interior of the RV. I was told they are expensive...around $4k or so I have no idea of the rating of the motor. May I suggest you locate a dealer that has one and have them run the test? BTW some SOB manufacturers website shows one...I just can't remember who's
Aaron
WBCCI #XXXX AIR #2495
Old 10-17-2004, 05:50 AM   #3
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
leak
Hi Bob, We just located a water leak in our trailer by spraying a soap solution on the outside and using a small air compressor on the inside where the water was showing up and found the leak about 4ft away from where the water was coming in. Sounds like this would work for you too. Good luck. Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 10-17-2004, 11:23 AM   #4
Images: 59
Here's a leak tester.
http://www.rvleaks.com/how.htm
I finally discovered a use for that old furnace blower.
Old 10-17-2004, 04:08 PM   #5
greg176's Avatar
Gabriola Island , British Columbia
Perhaps a shop-vac inside the trailer and taped up to one of the vents might work.You would have to tape up the plumbing and fridge vents too.
greg176 is offline   Reply With Quote
Old 10-17-2004, 04:38 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
That's it!
That is the one I saw...but how much?
Aaron
Old 10-17-2004, 04:44 PM   #7
Images: 59
Aaron
Probably up to the dealer/service mgr. There are hundreds of locations listed on their web site.
Old 10-17-2004, 09:26 PM   #8
mcneon's Avatar
Greg176's suggestion makes me think that a leaf blower might do the trick. Those things put out a pretty high volume of air. They're not designed to work against a high outlet pressure, but that's probably not an issue with all the possible outlet points in my motorhome.
My notion would be to tape up my aged window and door weatherstrip, the plumbing vents, and maybe the door on my inverter compartment, and see what happens. Since I'd be pressurizing the interior, taping dry cleaning bags over the inside of windows, air conditioner, and such might work, too. I'm also thinking that, if one leaf blower didn't give enough oomph, adding a second or third might just do the trick.
Old 10-17-2004, 10:47 PM   #9
greg176's Avatar
I repair leaks in aircraft fuel tanks by going in the tank and applying a 2psi negative pressure to the tank and using bubble fluid to detect the source of the leak.Kids bubble fluid watered down works best.A big leak like you would have in a trailer would not take much pressure to detect.I plan to try the shop-vac as soon as I finish the skin replacement.I will be using a water manometer to measure pressure.
A word of warning .There is a good chance that you will cause more leaks than you fix by pressurizing your Airstream.
60" of water equals 2psi .I don't plan to try more than 12".
Old 10-17-2004, 10:50 PM   #10
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
Lightbulb
That's an interesting approach to one of the more difficult problems to fix.
RivetED is offline   Reply With Quote
Old 10-17-2004, 11:01 PM   #11
Images: 59
I think I would go through about 10 rolls of duck tape before I could get as high as 12". Unless I had a nice jet turbine for a fan.
Old 10-17-2004, 11:21 PM   #12
greg176's Avatar
That 12" is very roughly .4 PSI and is probably a bit much for a trailer does 3" sound better (I do tend to exagerate).I do plan to give the shop-vac a try but it looks to be next summer some time.Right now it is not a problem to find leaks in the pouring rain here.The problem is keeping ahead of them.
Old 10-18-2004, 06:15 AM   #13
Images: 59
Greg,
I wasn't disputing with your choice of numbers. I was commenting on how much work I need to do yet.
I haven't got my windows reglazed, the door gasket replaced, the solardome remounted, wheel wells replaced . .
. . . . . .probably next spring for me.
Old 10-18-2004, 06:45 AM   #14
mcneon's Avatar
It sounds like you analyze those tank leaks while you're physically inside the tank, so I'm assuming you work on BIG tanks. My problem is that seeing bubbles on the inside doesn't tell me much about the source of the leak. I can easily see where the water comes out, I just can't figure out where it's getting in! (If a guy had just finished a floor replacement and had all of the interior skin off, the vacuum approach would probably be a wonderful way to find and eliminate leaks.)
I found some discussion on a GMC MH website about using a furnace blower as the pressure source. They use a length of 12" flex duct to connect to a vent window, and several people reported very good luck with that method. I have an HVAC blower cabinet in my shop, so I think that's what I'll try first.
If I find my main leak with this method, I think I'll test around every window and body seam while I'm at it. I'm concerned that, with a 30-year-old sealant job, there could be minor leaks appearing that might go unnoticed for a long time.
Old 10-18-2004, 07:12 AM   #15
greg176's Avatar
I was suggesting putting the shop-vac inside the trailer sucking in through the vent, that would pressurize the trailer.BTW those tanks I work in are usually in the B737 and just big enough for me to drag myself into.It's not pretty.
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
Air Bag Pressure Checking and Adjustment noiva General Motorhome Topics 2 07-30-2004 09:17 PM
Toilet Sprayer Valve Leak 66Overlander Sinks, Showers & Toilets 6 06-21-2004 01:03 AM
Do I have a leak? melprice Water Heaters, Filters & Pumps 6 06-24-2002 08:35 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
