04-04-2006, 03:17 PM
1979 31' Excella 500
Detroit Area
, Michigan
My new (to me) airstream turns into nightmare
Just got down to some nitty gritty cleaning last night after it had rained all day and there seems to be water pretty much all the way down the edge of the street side floor. Found some moisture in bath behind toilet, was wet along wall/floor joint under twin bed. Can't tell about the refer and worst of all the floor was dry rotted to the point where there is a hole in it under the left hand side gaucho pad. Help, my dream has turned into a nightmare. Don't know where to start looking for water. Can see where vulkem had been used in the past to seal up all the usual culprits up top, but I wonder if the water isn't somehow coming from the trim strip that goes all the way around the bottom of the trailer. Really don't want to start tearing all the ceiling apart to find leak although I now wonder what kind of black mold might be up there PO of course said no leaks and I have no recourse. Any suggestions on how to patch a piece of dry rotted floor?
04-04-2006, 03:24 PM
1968 17' Caravel
Battle Ground
Search around the forum and you will find many people have had to patch up their floors, or replace them all together. It's not as bad as it sounds.
The water could be getting in through the panel seams. They need to be cleaned and resealed occasionally. I stopped most of the leaks in my trailer by sealing the seams.
Sorry to hear you're having such bad luck. It's a shocker when you find it, but unfortunately it's not all that unusual in old trailers.
Stephanie
04-04-2006, 04:44 PM
Detroit Area
, Michigan
It almost looks to me like the water is coming in through the rivets that hold that piece of blue trim to the bottom surrounding the trailer. Has anyone else had that problem? What's the easiest way to fix?
04-04-2006, 04:52 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Run a bead of caulk around the top edge of the extrusion, but to do it right you need to take the blue insert out, drill the rivets out, thorougly clean behind the extrusion and the back side of it. Then lay a bead of vulkem on the backside of the extrusion where the rivets go thru, then replace and place a small bead of caulk around the top edge of the extrusion. That is what I am doing with mine as I get to it.
Aaron
WBCCI #XXXX AIR #2495
04-04-2006, 05:03 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
start with the sewer vents.
john
you call them ferrets, i call them weasels.
04-04-2006, 06:36 PM
Detroit Area
, Michigan
The sewer vents would cause a leak way up by the gaucho?
1976 25' Caravanner
Campton
, New Hampshire
Not sure what year you are working on but on my '76 I had a similar problem . I took off that lower moulding to find the leak and it was not the problem . The lower belly roll goes under the side alum. sheet so the water would have to go up for it to leak . I guess if it was a bad seal and you drove in heavy rain it could leak . Mine turned out to be a vistaview window . Try using a garden hose on one section at a time to see if you can narrow it down . If you have soft floors it's been going on for quit some time , which makes me believe it's happening while the trailer is stationary . Good luck and don't give up
04-04-2006, 06:46 PM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Check out my site, I had a similar problem, all kinds of pics and tricks...
Good Luck, what year is your rig?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
04-04-2006, 07:16 PM
1975 31' Sovereign
Oxford
, Mississippi
We had the same problem by the gaucho, in fact when we removed the gaucho my husband fell thru the floor. After we pulled all the rot out we ran a water hose on the outside and we found the leak around the front where the belly wrap is. We vulkemed around the top of the molding where the blue band and presto it was fixed. We searched for about a month to find that leak. I wish we had done what Aaron was talking about.
Becky
Look under my pictures and you will see what our leak looked like. Sounds alot like yours.
04-04-2006, 08:11 PM
Detroit Area
, Michigan
It's a 1979 Sovergn 31'. I started looking around the windows and noticed that one of the lower windows was wet when I pryed the plastic surround around it with my finger. Perhaps it is the windows. When you say run a hose and watch, I don't understand how you can see where the water is coming in with the inner shell of the coach intact.
04-04-2006, 08:33 PM
1963 16' Bambi
Yreka
Also look for loose screws and rivets, the water can creep in around and along such items and into the wood floor. When I took my Bambi apart one of the largest leaks I found was the Bambi script itself. These logos are held on with simple clips on the back of the outside skin. Water travels around the curve of the trailer and right to these logos.
good luck!
Don
04-05-2006, 10:03 AM
1953 25' Cruiser
Canton
, Mississippi
What ever you do, DO NOT USE SILICONE SEALANT ON THE OUTSIDE OF THE TRAILER. It will deteriorate in a few years and is just about impossible to remove. It is not compatible with aluminum.
04-05-2006, 11:02 AM
1975 31' Sovereign
Oxford
, Mississippi
Aint that the truth!!!!
Silicone is a curse!!! I've been working on the top of the trailer for the past 2 days and one of the past owners used silicone it is just awfull not to mention a pain in the rear to get off.
Becky
04-05-2006, 11:28 AM
Remember, Safety Third
Catfish Corners
, Georgia
You've gottten some good advice so far. Don't panic, everything will be ok.
What they mean by using the hose is: Get a helper, have him/her stand outside the camper with the hose on, start spraying the outside from the bottom and slowly work toward the top of the trailer, one section at a time. You go inside the trailer with a good flashlight and look for leaks in the area that is being sprayed by your helper. You can find most leaks in this manner, but you may have to take a few things apart to repair some of those leaks. Don't worry, we can help with that, too.
The "Gaucho leak" that you have, we had, too. Turns out that one of the wires to the front running lights above the front window had broken the seal on the Vulkem. Water leaked in above the window, ran around the widow frame into the floor and rotted the floor out.
Hope this helps a bit.
04-05-2006, 11:46 AM
Detroit Area
, Michigan
Well I am kind of panicked as you might be able to tell. I paid a decent price for this thing and now I feel burned and disappointed with a little dispair thrown in.
04-05-2006, 11:59 AM
2016 25' Flying Cloud
Sunnyvale
Disappointed yes, despair.. No!
Wac-
It might even be possible that prior owners (PO's) were really unaware of the leaks, having just parked it and loked inside once in a while. The floor rot is the primary reason for the excellent suggestions here to take an ice pick on an inspection tour, to get under carpet and test wood flooring..
There are other possible sources, though windows, running lights and seams are good places to start. It does help to have someone else with enthusiasm and a gargen hose, but other possible sources of leakage could include the bath vent, the roof vents (riveted and sealed around flange and visible only from ladder on roof), the TV antenna, air conditioner cover and gasket seal or the door(s). Prior threads are correct to suggest water won't flow uphill, but might flow a long way down a gentle slope... (also good physics ) .
Consider posting a sign somewhere reminding yourself that new 31' airstreams cost well over $50,000, and some labor and materials to enhance your new purchase are money well spent.
John McG
Condoluminum
04-05-2006, 12:14 PM
Detroit Area
, Michigan
Yeah thanks for the encouragement. We did spend about two hours inspecting this thing when I bought it, but we didn't pull the gaucho arm off and check the floor back there.
04-05-2006, 12:24 PM
Sunnyvale
It's a lifelong project...
Just to clarify, since acquiring our beloved '88 Excella 25 in early 2003, we have had to deal with leaks from:
1. Bath Vent (plastic dome split open during 2005 Rose Parade Rally Downpours and needed replacement).
2. Air Conditioner Gasket (Water dropped onto floor under A/C after prolonged use in high humidity, or thunderstorms, and did both at Oshkosh Air Show in 2004..)
3. Leak along upper edge of front curved window, resulting in dribble down inside of glass and resealing including around front running lights
4. Leak around flange of replacement Fantastic Fans for original metal lid vents, as roof not as flat as flange wanted to be....
5. Leak along seam of small porch light over entrance door, running down side of inner door frame...
Fortunately, not chronic, and when we redid front couch and carpeting and upholstered panels behind it we were able to verify no damage to sub-flooring anywhere. Remember American Express AND Vulkem... Don't leave home without 'em...
John McG
Condoluminum
04-05-2006, 07:15 PM
Detroit Area
, Michigan
This is sick. I don't have the time or money to make all these repairs. I'm going to take a bath on this thing.
04-05-2006, 08:41 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
wac
you won't take a bath on it.
you just need to view it just like a house, something always need fixing.
i believe airstreams are in a state of perpetual destruction from the moment they leave the factory.
get it to the point you can enjoy it and just go camping!
john
