Old 12-13-2009, 05:46 PM   #1
hilton Head , South Carolina
Exclamation Leak repair
I just recently had my 2004 Safari repaired for a leak in the right back bottom closet (floor was wet). The dealer did a pressure test and said that they repaired the leak and said I should be leak-free. I brought it home, it rained today and now I have a leak on the floor near the couch under the breaker box and also a drip over the kitchen counter. Could there be a problem from a leak down below since the dealer claims they repaired all leaks from above? The trip to the dealer cost me over $800 for the pressurized test and sealants on the roof and a service to the Airstream itself.
pullonofhhi is offline   Reply With Quote
Old 12-13-2009, 06:57 PM   #2
Perhaps the leak in the closet is from a bad sewer vent pipe cover gasket.
Are all of the opening windows latched "very well"?
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-13-2009, 07:07 PM   #3
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
Hi Surfinsafari...
Thats a cool name. Welcome to the forums..
Sounds like their work is not done. You just spent $800 dollars to have the trailer pressurized and checked but mother nature always finds a way. I would give them a call and advise them of your frustration. In the mean time a dehumidifier with all the drawers and cabinents open would help with excess moisture to minimize any damage to the flooring. Is this trailer new to you or have you owned since new? First time you noticed any leakage? Note the places that you see the leakage and try to do your own inspection of those areas outside where you think the water might be coming in. If the roof was sealed maybe its a window or something attached to the outside skin that needs caulking. Start with the phone call and see what they will do for you.. maybe its a simple reimbursement and you start over with someone else..
Good luck
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Water Leak Repair dawnasoo 1961 - 1963 Bambi 0 07-27-2008 07:14 PM
window leak/repair/replace? gwendolyn Windows & Screens 1 01-22-2006 10:09 AM
Water Leak, Floor Repair Cstar Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 02-05-2005 04:58 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
