2005 28' Safari Leaking at Skin to Belly Pan Location
I have just purchased a 2005 28' Safari. We are remodeling it and trying to find all the leaks and fix them. I have noticed the plywood floor wet at the Chanel and interior skin. I have taken off some of the interior skin but all the walls are dry. Next I removed the lower moulding trim where the exterior skin and belly pan meet. There is no caulk in this seam and no putty tape under the trim strip. Has anyone else encountered this? What is the best way to ensure this seam is water tight and after I reinstall the moulding strip should it then be caulked?
Thanks for helping,
Rich
