Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 03-13-2022, 08:28 AM   #441
prostar's Avatar
2020 27' Flying Cloud
Allen , Texas
Excellent tips. We’re your skylights the same size as the post above yours? 22.75X22.75 and 17.75X26.25. What year and model trailer did you do the install on?
prostar is offline   Reply With Quote
Old 03-13-2022, 09:14 AM   #442
Cave Creek , Arizona
I have Maxim skylights on order and am waiting for them to arrive. I’ve been reading up to prepare for the instal and this thread has good information. One thing I noticed was Maxim recommended using a Neutral Cure adhesive sealant. My first thought was to use Sikaflex 221 but its not the right choice in this case. Going with Silco RTV7500 instead
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Old 04-19-2022, 06:38 PM   #443
2019 27' Tommy Bahama
It was our 2019 TB FB 27. I think those are the correct dimensions (one is square, one is rectangular)
TEST RESULTS - We took it up to N. CA and ran into a ton of rain, both while driving and camping. It was completely water tight! Also ran into a major wind storm and no issues at all (not that they were expected). Finally took it boon docking in AZ in 90+ clear, sunny skies. The lowered heat gain was remarkable! No more "magnify glass on ant" feeling at all! I highly recommend this improvement!
Mark of SJC is offline   Reply With Quote
Old 04-20-2022, 01:02 AM   #444
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
👍 Ditto here.
F450Harley is offline   Reply With Quote
Old 04-20-2022, 06:01 AM   #445
dznf0g's Avatar
Oswego , Illinois
Mine have been installed for 10 years. No leaks. There are, of course, tiny scratches from cleaning and normal use. Some of the corners of the dome poly have developed small surface micro-cracks, or checking in the very corners where the dome meets the frame corners. I don't think it is a big deal. They have been there for several years. Only cleaned with plain water no chemicals nor detergents.
-Rich-
Old 06-23-2022, 09:50 AM   #446
bigfoot390's Avatar
1999 30' Excella 1000
Chatham , Virginia
Originally Posted by Bambi_Bandit View Post
Since we are going in horizontally and thru caulk blindly into the curb, a self tapping fastener is the ideal. Drilling would be a pain...
I went to home depot and purchased Crown Bolt #10 x 1 1/4 inch self tapping metal fasteners, as well as palram wood screws (metal roofing section) with and EDPM washers.
I then took the washers off the Palram wood screws and put them on the crown bolts. A self tapping fastener with EDPM washer. No drill needed now!!!
Product Information Error Page
Woodtite Woodtite 1 In. - 50 Pc. - 92522 at The Home Depot
Make sure the screws are Stainless steel
bigfoot390 is offline   Reply With Quote
Old 06-24-2022, 06:32 AM   #447
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
Just an FYI,, when i installed our new maxium in 2015 after removing the old thin cover with all the screws I used a file to get the area where the screw holes had created a the extra metal to raise up above the frame to make sure everything was nice and flat..
I then used some 120 grit sandpaper to rough up the top of the flange and applied a bead of Sil Flex RTV 7500 adheave on top of flange, set the new skylight done on the bead and pressed lightly to make sure it was on the bead completely.. let it dry and now some 6 plus year and 25K miles of towing from east coast to west coast and back NOT one problem..
you don't need a bunch of screws on the top.. actually you don't need ANY screws.. the adhesive will work fine.. good luck..
https://www.amazon.com/SIL-FLEX-RTV-.../dp/B09CLZ5CDV
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 10-17-2023, 09:26 PM   #448
matthorr's Avatar
2012 25' FB International
Colorado Springs , Colorado
I just installed a Maxim after my original skylight was damaged by hail. I ordered 2 layers of light gray (they were out of dark gray - the two layers of light gray let in the same amount of light transmission as the single white or single dark gray but let you see out). I couldn’t feel any heat from the Colorado sun radiate through. It looks as dark as the original but much cooler. I also chose anodized (vice natural) aluminum for the frame. It doesn’t look much different from bare aluminum but will hopefully be a little more durable. Wish I had done this earlier!
matthorr is offline   Reply With Quote
Old 10-18-2023, 07:23 AM   #449
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Old saying: "Better late than never!" We did Maxim skylights as part of the first of many modifications after delivery.
Coming up on 10 years in the Classic and 9 years on the 23D.
Old 10-19-2023, 08:04 AM   #450
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Congrats Switz! We put our Maxim's on 10 years ago (post #140) and they've been one of the best upgrades we've done! They really help with the temp control in the trailer.
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
oem skylights, replace
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
Step by Step Repair for 1965 Caravel jlovelady Steps 2 12-19-2009 02:23 PM
Skylights on 75 sovereign bdbluegrass Roof Vents, Skylights & Fans 5 08-21-2006 07:26 PM
Skylights..... Silvertwinkie Our Community 4 08-14-2003 08:32 AM
