Old 08-23-2004, 07:59 AM   #1
nevisstudio's Avatar
Images: 8
Skylight Insight
HELLO ALL..
IM TRYING TO PUT A SKYLIGHT IN THE FRONT OPENNING, WHICH MEASURES 14"x25"....
HAS ANYONE DONE AN OPERABLE ONE OR FIXED..
WOULD LOVE TO KNOW WHICH ONE U USED AND PROS/CONS...
THANKS
RICH
nevisstudio is offline   Reply With Quote
Old 08-23-2004, 09:37 AM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hi Rich,
When I purchased my trailer, it was missing the big skylight cover. In the long run, I ended up making one from lexan and two different sizes of aluminum angle. I had a couple of the vent lifters mechanisms and they were utilized so the homemade vent cover operates just like the original was intended. Do you have the original lifter mechanisms? That would be all you would need from the original set up. I've got pictures around here somewhere. I'll post them to this thread.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-28-2004, 09:32 AM   #3
nevisstudio.
We have the replacement "Astrodomes" both in milk white and solar gray.
We also have the lift operators.
Andy Rogozinski
Inland RV Center
Corona, CA
Diesel Mtrhm Data 1995 - 2003 phred Airstream Motorhome Forums 5 08-17-2011 02:12 PM
Sky Light Problems jalewis Roof Vents, Skylights & Fans 12 05-07-2008 07:51 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Double seals on skylight? TomW Roof Vents, Skylights & Fans 1 03-01-2004 08:44 AM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 09:16 AM
