Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 10-13-2007, 08:31 PM   #1
Director's Avatar
1965 26' Overlander
Sevierville , Tennessee
Removing screens in ceiling vents
I have a (new to me) 1965 26' Overlander. It has two ceiling vents fore and aft. There are two knobs which turn to raise the cover and allow the fresh air in (and presumably the hot air out). I want to clean and remove the screens and it looks like to do so one must remover the knobs. I notice some small holes in the shaft of the nobs for that purpose, but I'm not sure if that is the answer, they seem too small for an allen wrench... any one with the correct answer so I can get the cob webs out and wasp nests too...??
Thanks!
Director
Director is offline   Reply With Quote
Old 10-13-2007, 08:57 PM   #2
1960 24' Tradewind
santa barbara , California
Hello DIRECTOR ,
the knobs just pull straight down off the operators ,the operator shaft has a spring loaded ball bearing that secures the knob .The screens then can be carefully pulled down also .I cleaned ours with soap and water ,huge difference ,they look brand new .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 10-14-2007, 01:24 PM   #3
Director's Avatar
1965 26' Overlander
Just "pull" and the vent knobs will come off! Great!
Originally Posted by scottanlily
Hello DIRECTOR ,
Thanks Scott! Just my luck I would have tried something and without knowing what to do and I would have broken off the handle! I'll give it a try...just pull eh?
Thanks a bunch!
Director
Old 10-14-2007, 06:22 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Scott was right, just pull down. Try and support the rest of the knob mechanism to prevent bending of the support bracket but the knob just pulls off as described above.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
clancy_boy is offline   Reply With Quote
Old 10-15-2007, 05:21 PM   #5
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Scott, thanks! I always thought I needed an Allen wrench in those little holes. I'd been putting off investigating further for months. Now I can do that screen cleaning that is much overdue.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Old 12-31-2007, 08:15 PM   #6
airdrmr's Avatar
1967 22' Safari
Santa Barbara , California
Images: 12
roof vent gasket
I have the same roof vents on my '67 safari. I need to replace the gasket that seals the vent when it is closed. Can anyone steer me in the right direction for a replacement gasket? It's hard for me to tell what it should look like since so little of the original gasket is still there.
Thanks for any assistance.
Meredith
hey you, get off of my flying cloud
airdrmr is offline   Reply With Quote
Old 12-31-2007, 08:44 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
This is what we used
This is available from Inland RV or check your local hardware.
Old 12-31-2007, 08:53 PM   #8
airdrmr's Avatar
1967 22' Safari
Images: 12
ah, yes....
Thanks, Gary. That does look vaugly like what is left of mine. Do you glue it down?
Meredith
Old 12-31-2007, 10:15 PM   #9
The ceiling vent gasket has an adhesive backing.
Remove the old gasket, clean the surface "VERY WELL," take the paper backing off the new gasket, and simply apply the gasket to the bottom side of the vent cover.
The square covers (solardomes) use 5 feet and the rectangular covers (astrodomes) use 7 feet.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-01-2008, 12:52 AM   #10
airdrmr's Avatar
1967 22' Safari
Images: 12
Thanks, Andy!
by the way, this is waaaay off this topic, but I bumped into someone the other day who had an airstream a little older than mine and it had this neat A/C shroud. It was silver and it looked like aluminum. He said he got it from Inland. I am wondering if his shroud could be part #69807, put it's painted?
Thanks again,
Meredith
Old 01-01-2008, 06:37 AM   #11
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You do not want to use the open cell foam gasket material that is shown above. It allows water to come right thru it as well as air when not fully compressed. If you compress it fully, then it takes a set. 3M and others offer a closed cell version of this gasket material with adhesive attached which is much preferred. The closed cell version also has longer life as it is not completely exposed to the air and has more material in it.
dwightdi is offline   Reply With Quote
Old 01-01-2008, 06:41 AM   #12
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Meridith,
With the right paint and prep and I strees prep yes you can paint almost anything. I want to apint my AC shroud silver as well. A good wipe down with de-natured alcohol and some krylon fusion should do the trick.
They don't appear to have silvver but they do have a pewter grey that looks close.
If the krylon fusion does not work color wise. A primer and a normal spray paint should work fine.
Michelle TAC MT-0
Sarah, Snowball
thecatsandi is offline   Reply With Quote
Old 01-01-2008, 08:02 AM   #13
Thanks, Andy!
Thanks again,
All of our AC shrouds have a gel coat exterior.
You can easily paint them any color you wish.
We suggest that you use a decent quality paint.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-01-2008, 08:07 AM   #14
Airstream has used the open cell vent cover gasket for over 40 years, with absolutely no problems, except those related to age.
When the cover is down, the gasket is compressed. It would take a direct blast of water from a high pressure hose to go thru it.
Also, the open cell gasket does not take a set, unless the covers stay closed for many many years.
The same type gasket has been used on the screen doors since 1965, also with great success. It doesn't compress there, either.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-01-2008, 08:21 AM   #15
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I like the open cell for the exact reason that it allows a least a minimum of heat migration out of the trailer when it's closed up. We close the vents down just until the gasket seats and have never had any water get in. Heat build up in the trailer is the enemy of laminates, drapes and upholstery in our experience.
Old 07-14-2008, 06:02 PM   #16
1951 21' Flying Cloud
burbank , California
I have posted a picture of my ceiling vents here on my blog.
Sweater Surgery: Airstream vent parts missing
is this the mechanism you are talking about? I am missing all the handle/knobs on my 51 Flying cloud and am looking for the missing part/handle any advice or can you send a picture of what is missing?
Stef
plaidbunny@aol.com
plaidbunny@a is offline   Reply With Quote
'68 Safari Screens 63Airstream Windows & Screens 1 03-17-2007 08:12 PM
Argosy screens misterbee All Argosy Trailers 17 08-03-2006 05:14 PM
Repairing screens wacnstac Windows & Screens 6 06-19-2006 07:49 AM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
changing screens Perry Windows & Screens 5 02-22-2003 02:20 AM
