Originally Posted by gregwall
There is a very simple answer to this. I am trying to remember what it was, but we had the same problem last summer. I think I turned the fan on and nothing happened, so I did as you, manually opening the vent. As I remember, the speed dial has to be on a number, not 0, or it won't open. I think that was it.
There is nothing simple about the FantasticDamnFan...🥴
With the fan off, open it manually, just before fully open engage the motor, and continue turning.
When it's up as far as it will go.With the thermo on full cold,(if equipped), turn the power switch on and select your fan speed...or maybe it was the other way around...fandamit. 🤔
