Chris
need to see the handle to know for sure, but go to thread "1964 mystery hehr side windows-need operators" by member ts8501. His are that style on the sides mine are like that everywhere! How did you make out with the door?
Kevin
Thanks Kevin, it seems that what you sent me should be exact. Most of the handles are like pictured here. Seems I should be able to order those up From Blaine and move on to better things.
Would VTS carry the weather sealing products for these windows?
As for the door, I believe I found one, I just have to check on shipping. Thanks for asking, I'll keep you updated.
I dont think they have the gasket, so treat it carefully you may have to re-use it. The windows you have are the best looking(I think) and easiest to change glass on that airstream made BUT very rare and hard to get parts for. If you find another door w/in a door in your cyber travels let me know, I have one but it is bent.
and before you do anything realize that most of these oldies have bad axles, bad floors esp in the bath and door areas, rear end separation and will require some frame repair. I'm a real cheery guy!
Kevin
