Old 06-25-2017, 05:46 PM   #1
2016 25' Flying Cloud
Silverthorne , Colorado
Shade removal
I've got a 2016 Flying Cloud and need to remove the window shades. The plastic end brackets seem permantly attached to wall. Any tricks to know before I try brute force?
A B4 D is offline   Reply With Quote
Old 06-25-2017, 05:49 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Plastic plugs in end brackets pop out and expose Phillips screws under them
Old 06-25-2017, 07:31 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The plastic end plugs pop out even when you *don't* want them to. They attach with two little "prongs" that snap into the cross bar. Be careful of the prongs when you pop them off. The issue isn't so much getting new caps. It's getting the remains of the "prong" out of the cross bar.
Old 02-04-2023, 02:22 PM   #4
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
How do you “pop out” the plastic plug?
Jim Flower is offline   Reply With Quote
Old 02-14-2023, 08:11 AM   #5
Jim Flower's Avatar
1997 25' Safari
I will try again. How do you “pop out the plastic plugs” that cover the attachment screws? Jim
Old 02-14-2023, 12:07 PM   #6
Jeff7176's Avatar
2018 25' International
Full-time , Traveler
I don’t know if there is a correct way to do it, but I had one pop out when I missed the hold down hook and the shade slammed open.
From what I can tell, you should be able to take a small screwdriver or pocket knife and gently lever the plug out.
Alternatively, you could probably get a dowel that has a slightly smaller diameter and put some hot glue on the end, stick that to the plug, and pull it out that way. Not sure if that would work, but I’ve seen it done in other applications.
Jeff7176 is offline   Reply With Quote
Vista window shade removal just2drive General Interior Topics 4 05-26-2016 11:59 AM
Rivet Removal Tool OR Blind Rivet Removal T mkamanu General Interior Topics 3 10-12-2015 07:29 PM
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 07:58 AM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
