Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 11-15-2010, 03:39 PM   #1
Trex's Avatar
1981 20' International
Shasta Lake City , California
Remove interior acrylic vista window...easy!
After looking at a thread on "How to remove the plastic acrylic interior vista windows", I thought that I would give it a “go”. It took less than an hour to do the whole operation, and a lot easier than I thought it would be.
Using a Dremmel drill tool, I set the depth gage so I wouldn’t contact the corning glass exterior window and simply went around the window frame work, using it as my guide for the tool.
Once I cut out the main body of the old window, I made vertical cuts towards the aluminum window frame.
Than using “vise grips”, I started pulling out the sections of acrylic left in the rubber gasket and aluminum framework, starting at the bottom.
Once I had the bottom section removed, I pulled on the rubber gasket and the rest of the top half of the acrylic window fell out.
Each vista window in my 72/31’ has a separate channel framework for the acrylic window and the corning glass window, so removing the interior acrylic has no effect on the exterior window.
Make sure you use eye, ear protection and gloves!!!!!
Now I need to remove the interior wing windows…. Doesn’t look like an easy task, like the vista windows!!!!! Trex
Trex is offline   Reply With Quote
Old 06-22-2013, 08:04 PM   #2
lasgambler's Avatar
1973 31' Sovereign
Yucca , Arizona
Were you able to cut out the interior wing windows?
lasgambler is offline   Reply With Quote
Help on ACRYLIC WINDOW REPLACEMENT, '79 Argosy campman All Argosy Trailers 23 03-06-2015 07:05 AM
How do you remove Vista View shades? Tikiman Windows & Screens 4 08-24-2009 11:41 PM
Vista View Interior Edging? mello mike Windows & Screens 10 06-05-2009 09:22 PM
edging around interior vista window Lothlorian General Interior Topics 1 08-23-2008 05:35 PM
Acrylic window care Janet H All Argosy Trailers 4 06-29-2004 11:54 AM
