Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 03-22-2019, 09:26 AM   #1
1972 27' Overlander
Lamar , Missouri
Plastic window positioner broken
I'm working on my windows on my 72 overlander and the bottom position of all 7 window opener brackets are broken. I have found replacements available, $14/set.
My question is to people use the bottom bracket or mostly the upper two? I am using the 2nd position and it seems the windows stick out a lot. It looks easy to replace the brackets. Easier than the floor, plumbing, black tank, etc. Thks
walleye001 is offline   Reply With Quote
LED running light plastic mounting tabs broken...... RxGuy Lights - Interior & Exterior 2 07-04-2018 09:23 AM
Broken plastic rear light? Argosy facade on rear tomzargosy All Argosy Trailers 9 06-11-2011 10:45 PM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Lance M Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
