Originally Posted by goldie
I just purchased a 1970 airstream caravel that's in pretty good shape. I have very little experience with the restoration of anything but I am so excited about this. There are things I can do initially like, purchase propane tanks, replace rock guard, replace the steps and some vents, and the biggie; replace the rear window. I've been staring at that rear window for about a week and I have no idea how to get that thing out without removing rivets! It needs tempered, tinted glass and I have no idea what i'm doing. If I called a moble glass guy, would they be able to do this? Is this something I can do myself? It has been rumored that this is the place for help. Help!!!
Hi Adrian.
There are many parts still available for your Caravel.
Once you know how, replacing the rear window takes all of 10 minutes and can be done by most anyone, including ladies.
First, remove the window lift arms from the side of the window.
Next, from the outside, raise the frame that was around the glass, so that it's almost totally vertical over your head.
At that point, the glass frame (sash) will fall out.
Be careful of the broken glass.
Install the new window in the reverse order of removal.
The hinge is a double "J".
With a large window, you must make sure that the 2 pieces of hinge are engaged properly, and then slowly lower the window.
CAUTION: If the hinges are "not" aligned properly, they will be damaged when lowering the new window.
