Old 01-13-2018, 06:42 AM   #1
1951 21' Flying Cloud
1954 22' Flying Cloud
columbus , Ohio
Hehr windows
On my 1954 Whale Tail I have enlarged the curb side closet to accommodate a toilet, turned out great and looks original, but I would like to add a window. The other windows are Hehr, 9" overall height, 6 3/8 glass size, does anyone know where I might buy such a window? width does not matter, as I plan on narrowing it to 12".
ID:	302324   Click image for larger version
finn21 is offline   Reply With Quote
Old 01-13-2018, 02:46 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Watch Ebay, Airstream and Vintage trailers. The windows were used on many trailer brands in that time frame.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 01-24-2018, 05:37 AM   #3
columbus , Ohio
hehr window
Yes, I have had an ebay search for over a year, and have called all the vintage trailer used parts people I know, some one has to have one!
Old 01-24-2018, 06:25 AM   #4
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
Picture?
I have a bunch of old camper stuff around. Can you share a picture of the Hehr style window you are searching for?
PA BAMBI II is offline   Reply With Quote
Old 01-24-2018, 07:47 AM   #5
Central , Mississippi
The window and backframe can be fabricated from flat stock .025/.032 aluminum. 2024T3 won't work, it's too hard and will crack but 3003 is widely available and works nice. I've made a few of these. The extrusion and cranks are available from Vintage Trailer Supply. The rolled hinge is a horrible part to create, consider using a piano hinge hidden on the backside.
Contact a local sheet metal shop and see if they can cut/fold up the pieces for you by copying one of your existing windows.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 01-24-2018, 06:54 PM   #6
columbus , Ohio
hehr window
I am posting pics of the existing windows, I believe they are called "Hehr standard". I have considered reproducing one, but it will be so much easier to narrow a larger one. I have an aluminium tech that could cut them apart and you would not be able to find the seam!
ID:	302958   Click image for larger version
Old 03-01-2018, 03:19 AM   #7
54 Flying Cloud
KrisE MN's Avatar
1967 20' Globetrotter
Grand Rapids , Minnesota
I think I have a handle on some 6x18 New Old Stock
I'm planning on the same remodel. These have the lever pull out, not crank. I'm pretty certain these are the model used for the year you're looking.
KrisE MN is offline   Reply With Quote
Old 03-02-2018, 05:26 AM   #8
columbus , Ohio
hehr window
So you have one I could buy?
Old 03-03-2018, 05:22 AM   #9
54 Flying Cloud
KrisE MN's Avatar
I'll know next week and keep you informed
He's at a show right now.
Old 03-16-2018, 07:21 AM   #10
columbus , Ohio
window
Any update?
Old 10-24-2020, 07:41 AM   #11
1953 21' Flying Cloud
Harrisville , Utah
IwhT about doing a sky light if you can’t find one. I am also trying to change things up a bit and thought about how dark it would be. My idea was to put a sky light in?
Spearjodi is offline   Reply With Quote
Old 06-13-2021, 09:36 PM   #12
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Ballarat, Victoria , Australia
HiHo, could I trouble you for some photos of your windows, the process of making them or any advice?
I've been thinking that I could make them with my Panbrake. I tried folding up my pattern cut out of paper, I think it'll work?
I'd have them laser cut to get the internal curves nice and neat....
ID:	397385   Click image for larger version
Disco Stu is offline   Reply With Quote
Old 06-14-2021, 06:31 AM   #13
Your pattern looks great. I don’t have my notes here for the details but yes, a pan break is required and most importantly, the bend sequence. Work it out on your paper pattern because if you get it wrong, the final bends won’t fit into the break.
I used the break to form the 180 degree folds also. Make the first 120 bend, remove the part and insert backwards in to break with it’s mouth wide open. Then clamp closed the break to complete the fold
Old 07-14-2021, 08:32 PM   #14
1971 27' Overlander
1956 22' Safari
Lafayette , Louisiana
Anyone have any luck sourcing those rivets that hold the hinged to the frame?
Jsvidrine is offline   Reply With Quote
Hehr vs. Full tilt windows. Soyboy Windows & Screens 28 03-17-2012 07:55 AM
Upgrade Windows vs Hehr Windows??? TomR Windows & Screens 5 08-19-2009 05:08 PM
Replacement Hehr windows wander'n Windows & Screens 13 04-03-2008 09:12 PM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
1963 Hehr Windows uwe Windows & Screens 11 06-11-2006 08:39 AM
