Old 07-13-2021, 03:22 PM   #1
1964 24' Tradewind
Toronto , Ontario
Relocating/moving a window
Hello, has anyone relocated or moved a window? I am currently undergoing a shell off restoration of a 1963 Tradewind. It was a twin model, the two rear windows on the right and left side are very close to the back of the trailer and I would like to move them forward about 20” to accommodate my dream layout. I am not concerned with moving them so much as patching the the strip where the old opening was and having it look good. opinions and advice are appreciated. I am also considering removing every window frame to reseal, thoughts?
TW-Pilot is offline   Reply With Quote
Old 07-13-2021, 03:36 PM   #2
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I moved and resized every window in a 57 Overlander. I also moved the door to the rear of the trailer and made it swing the other way. It’s doable
My 57 Overlander thread ( Holly is her name)
https://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 07-13-2021, 04:52 PM   #3
1966 22' Safari
Fredericksburg , Texas
Like BradS said, it’s doable. I’m assuming the inside skin is out so you can buck the frame back onto the outer skin. Don’t cut any ribs. Add stringers around the new location. As far as patching, I don’t see it that noticeable if you plan on polishing the trailer. If that’s the plan, I would remove the top part of the outer skin from the left window jamb to the end cap and, top to bottom, from the awning rail to the joint right below the window jamb. Buck everything back together with modified brazier head rivets. Just a thought. Good luck
Bubba L is online now   Reply With Quote
Old 07-14-2021, 04:37 AM   #4
1964 24' Tradewind
Toronto , Ontario
Re:window move
Thanks Bubba, when you say not to cut any ribs, do you mean to say that I should be sure to place the window between existing ribs?
Old 07-14-2021, 05:50 AM   #5
1966 22' Safari
I sure would if it dimensionally works out.
Old 07-14-2021, 04:31 PM   #6
BradS's Avatar
1957 26' Overlander
Images: 14
When I got my 57 there multiple damaged ribs. After fixing that damage I became Confident. I cut a few ribs and I added new structure to carry the load. I’m a home builder so I have at least a working knowledge of loads. I bucked need skins over any holes and it sure seemed to work out ok. Go slow, ask questions and do your best
WBCCI 10289
TAC MN-69
AIR 11240
Old 07-14-2021, 06:14 PM   #7
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
Yup. It's not particularly difficult. I moved one from the rear to the front on my current trailer. I replace all the skin, exterior and interior so I didn't have to make any patches. I would mention that it helps to not locate the window right on a bow as the bows are curved and the windows are not.
truckasaurus is offline   Reply With Quote
relocating city water inlet stephenh2 Fresh Water Systems 9 10-16-2010 08:01 PM
Relocating Battery Box on 1976 Safari mile2885 General Repair Forum 0 07-18-2010 09:57 PM
Relocating strange gas line ? FreshAir LP Gas, Piping, Tanks & Regulators 8 08-04-2008 08:49 PM
If you were relocating ...... RIstream'n Off Topic Forum 101 04-26-2008 01:30 PM
Relocating tanks, sinks, shower, toilet etc. Billyb Sinks, Showers & Toilets 8 11-02-2004 12:21 AM
