Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 04-18-2009, 07:11 PM   #21
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Don't do what I done
On the photo of the deadbolt above:
Don't use a deadbolt to lock the screen door to the door frame for security without some kind of spring return. If the outer door locks to the screen door while the screen door is locked to the frame and you are outside, you are very effectively locked out. Just driving down the road can jiggle the dead bolt closed. I used a mini bungee cord to keep this from happening after locking myself out one too many times too many.
You can get in with a coat hanger. I've had the practice to develop it into an art form.
Old 04-18-2009, 07:19 PM   #22
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by Inland RV Center, In View Post
Some Airstream dealers have that old screen door latch.
But, from Airstream, they are rather expensive.
I will check out Home Depot as another source.
Thanks.
They didn't have them when I first looked, but I stumbled across this one recently. You may want to check multiple locations. The one nearest me has the worst selection and most out of stocks of any store I have been to, but it is on the way (and less than half the distance) to others.
Valid point.
This deadbolt attaches the screen door to the outer door itself, not the screen door to the frame. It allows you to use the screen door handle to move both doors at the same time. The screen door latches to the frame with a spring loaded roller.
Vaughan
Old 06-13-2010, 10:27 PM   #23
1983 34' Excella
1967 24' Tradewind
Images: 32
Thanks.
Hi again Andy,
I was in Home Depot the day before yesterday and found that they are now stocking the 4" long version like the original. I bought one to replace the small on in the photo just because it was (1) more original and (2) so cheap. It was $6.47.
It is an Everbilt (Eb) Surface Bolt and has the number 630 625 in the upper right corner.
Vaughan
Old 06-07-2020, 05:40 PM   #24
1971 21' Globetrotter
Blointville , Tennessee
latch disassemble
https://thegreatleys.com/journal/2016/11/6/how-to-disassemble-plastic-airstream-latches
416stroker is offline   Reply With Quote
Fixing screen door screen wacnstac Windows & Screens 8 04-09-2007 10:35 PM
Door hinges & new screen door? JKWoodrow Doors & Locks 5 11-17-2006 09:39 AM
Weather seal for '57 door and screen door cdmagda Doors & Locks 0 09-01-2005 09:40 AM
Door Bumper and Catch Assembly Source kayelm Doors & Locks 2 04-19-2005 10:59 AM
Accordian door catch Anon Cabinets, Counter Tops & Furnishings 4 03-12-2005 04:36 AM
