09-28-2014, 04:23 PM
1973 23' Safari
Buffalo
, New York
Is this is a sprung door fix?
Last year upon one of my first times transporting my 1973 Safari, I made the rookie move of leaving the door unlocked, thus a sprung door. Nifty way to start Airstream life.
Obviously not a huge issue that has stopped overall enjoyment of the trailer. Now - however - with the cold season coming and sizable gaps at the top of bottom of the door killing any notion of weatherproofing, I am hoping to fix it.
I've read some of the fixes on Airforums and I would prefer not to take the whole door off and apart. So, I am trying something and was looking for feedback from some experts as to whether this method might work.
The garage where I store my trailer all year is an old industrial space and I park the problem door right next to a VERY heavy duty steel beam that runs ceiling to floor.
Here's what I'm trying:
I've been careful to place the wood on the edge frame so as not to debt the door. Would love to know if this scenario might actually correct the problem or if it could screw up the door even more. Any comments/insight appreciated.
09-28-2014, 04:48 PM
Oswego
I don't believe it will "take" that shape by just sitting there under compression. I have adjusted my door by the method of sticking wood in the opening and hyper compressing the opposite end...but that is for a minor tweak. A sprung door probably needs the disassembly approach you have read about.
-Rich-
09-28-2014, 05:04 PM
Hollis
, New Hampshire
You need to figure out if the door frame is cast or not. If it Is, attempting to bend it with the 2 by 4 method will likely break it.
09-28-2014, 05:05 PM
1994 34' Excella
1978 31' Sovereign
Mansfield
, Georgia
I had a trailer with a sprung door and repaired it by using the techniques in the door forums. It takes approximately 2 hours if you have the proper tools such as a drill, cargo hold down strap with ratchet, correct pop rivets, drill bits and pop rivet gun.
I do not think exterior pressure alone on the door will work, it will just spring back. There is no structure to retain the shape after the external bracing is removed.
Removing the interior skin panels, use the cargo strap(s) to reshaping the door to correct curve. Re-attaching the interior skin panels allows the door to retain the new correct shape.
Tac GA-20
Air Forums 20320
09-28-2014, 07:35 PM
1981 31' Excella II
New Market
, Alabama
I would remove the door and find some way to apply a load to each end while it is supported in the middle. You will have to do this in stages so you don't put too much bend in it. It will spring back some so it will be trial and error.
Perry
09-28-2014, 07:57 PM
Corona
Attachment 223137
Attachment 223138
Assuming you have a 73, the door frame is an extrusion.
There are 2 ways to fix the issue.
1. Replace the door buy turning a cliam into your insyrance company. Yes, they pay claims that are caused by, and try to be nice, dumb things people do. It's called a MISTAKE.
Or, you can have the door repaired at the expense of the insurance company.
If you look carefully, you most likely will see a crack in the door frame, very close to the lock.
What your trying to do, will accomplish NOTHING.
Also, in either case, make sure you choose a dealer that has much Airstream metal and door work experience.
One last thing, check for wear on the striker bolt of the lock, and the wear on the brass shim that's located within the striker pocket.
If those show signs of wear, then, that in it's self can cause the door to fly open when you hit a bump.
Excessive wear of those 2 parts is caused by improper or lack of running gear balance, excessive rated hitch bars, or an excessive rated tow vehicle, or a combination of those.
The door area is a weak area, and is prone to become damaged by the above faults.
09-28-2014, 10:23 PM
1973 23' Safari
Buffalo
, New York
Thanks for all the replies that came through so quickly.
Obviously, I've been reading a lot here for the last year plus and I know that everyone has tried it all to fix something like this problem.
Particularly, I know Andy at Inland has a lifetime of knowledge and understanding with Airstreams, so his points are to be taken as a level of the greatest experience.
I didn't have the Airstream insured, when I got it, so there's no chance to get it fixed that way.
I knew I was shooting in the dark and hoping to fix it with an easy method was unlikely...
09-29-2014, 05:10 AM
1981 31' Excella II
New Market
, Alabama
If it is an extrusion it can be welded to repair the crack. A good aircraft mechanic could fix it. Everything can be fixed. Inspect that area around the lock for cracks. It is a good idea to have a secondary means of keeping the door shut. Mine has a dead bolt in addition to the lock on the door. Also locking the door helps it from popping open. Making sure that plunger has plenty of engagement is a good idea as well.
You can fab a wedge thing that goes in between the handle and the door as a safety measure.
Perry
09-29-2014, 08:46 AM
1973 23' Safari
Buffalo
, New York
There aren't any cracks on the door. The thing is: the door stays perfectly shut and locks up nice and tight. No chance of it flying open. It's just the top and bottom are a half to three quarters of an inch from "sealing."
09-29-2014, 09:45 AM
Oswego
ooo, with that much gap, you will need to remove it and remove the inner panels. Reshape and re-install inner panels. Sorry, but that's where you are, IMO.
-Rich-
09-29-2014, 11:04 AM
Corona
Here is a test for you to do.
Open the door.
Put one hand around the door, above the lock say one foot or so.
Put the other hand below the lock about 1 foot or so.
Then pull with one hand and push with the other.
The post a note as to what you found.
Then more help will follow.
10-04-2014, 12:07 PM
1973 23' Safari
Buffalo
, New York
Andy - I tried what you suggested - pushing and pulling above and below the lock - and what seems to happen is a buckling in the door just under the top hinge.
And as everyone pointed out after a week of having the wood putting the pressure on it had little to no effect on pushing it back to shape.
10-04-2014, 02:00 PM
1974 31' Excella 500
Charleston
, South Carolina
I'm With KeithC. I did the same thing. You can remove the door panels, reshape (and hold) the door then reattach the panels - with the door on. It worked for me.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
10-04-2014, 03:54 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
You might try this...
Remove the locking/opening hardware from the door.
Remove the door.
Place the door on two saw horses, outside down. Cover the horses so as not to scratch the outer door skin.
Remove the inner skin. Now you can inspect the entire framework inside the door for cracks or breaks.
Apply pressure to the door lock/opening hardware to re-shape the curve of the door. Do this little by little, setting the door back in place to find if it fits properly. Once you have the door fitting properly, any damage found to the framework can be repaired by a good welder.
Re-attach the inner door skin and then hang the door back on it's hinges.
Getting the door back to it's proper curvature will be much easier with the inner skin removed, plus, you will be able to examine door frame for damage from the inside of the door.
I experienced this on our Caravel, which has a cast door frame. The frame was cracked is several places and broken near the hinge. I had the cracks and the brake welded, then had inside gussets added at the stress areas at each end of the long, single, hinge.
Since your frame is an extrusion, you may be able to skip the welding part if there are no cracks or breaks.
Worked for me.
10-04-2014, 04:32 PM
Corona
I still feel that your door is cracked at the door lock area.
10-05-2014, 03:48 PM
1965 17' Caravel
1983 27' Excella
I'm with you Andy. With a cast frame, when there is a break, it is most likely to clear through the frame, but with an extrusion, the cracks could be on the sides of the extrusion covered by the inner and outer skins.
A few minutes with a screwdriver and a drill, and the inner skin comes off revealing any frame damage for all the world to see. This door has no window, making the job very easy.
10-05-2014, 08:24 PM
Corona
Jim.
The weakest part of the doors that used an extrusion for the door frame, is at the door lock area.
I stand by my guess.
10-06-2014, 03:15 PM
1981 31' Excella II
New Market
, Alabama
I think removing the inner skins is the thing to do cracks or not. Leaving it on the trailer may not be a bad thing because you have the opening to provide a reference to get the correct contour.
Perry
10-07-2014, 05:03 AM
Corona
Perry
Perry.
For simplicity, we always removed the interior metal, and closed the door.
Then we made the door fit properly.
Next, we tack welded the crack.
Then we finished the welding after we opened the door.
Of course, double checking to make sure nothing went wrong.
Part of fixing the cracks in a cast frame was to taper the cracks, which allowed a full weld.
You can do somewhat the same thing, but to a lesser extent to the extrusion
frames.
When reinstalling the old metal, DO NOT use the same holes, since they have wallowed out. Install new rivets in new holes, which locks the door into a proper angle, Then, and only then, after double checking the fit, install rivets into the old holes, which now serve nothing more than a decent appearance.
Restoring the original interior door strength is most important, and using just the old holes, will not in any sense allow that to happen.
