Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 05-26-2008, 09:50 AM   #1
1977 Argosy 24
Scarborough , Maine
Door Latch broken on '75 Argosy
Hi Help I can not get into my trailer. I have a 1975 Argosy and the latch is broken and the key just turns around. I tried the screws but they are soft and I fear they will just break off. Is there a way to get in. Then how do I replace the broken latch?????
debpatch is offline   Reply With Quote
Old 05-26-2008, 10:14 AM   #2
Retired.
. , At Large
I think you have the infamous "unobtainium" lock, but there may be a fix.
First (obviously), you'll need to be able to get into the trailer, the door should still open from inside. Does your trailer have any access compartments on the outside? If so, you can open the compartment, and a small child can get in, go to the door, and open it for you.
If you have no hatches to get in, are any of the windows unlatched? Again, a small person can crawl through and get the door open from inside.
Old 05-26-2008, 10:29 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hello debpatch -- Welcome to AIR Forums!
I've got two comments and they both will lead you to talking to Inland Andy at Inland RV. This is a $279 complete lock set that he has put together for this vintage Argosy trailer. Better yet -- the price may be much lower if you just need the KT cylinder lock. Tell him about the "key just turns around" and he may be able to lead you in the right direction.
Second -- we don't want to put this in print. He'll also tell you his secret on getting into your trailer ... on the assumption that you'll be able to open the door from the inside (another point to ask about, given your "key just turns around" problem). It will take some persuading to have them get him on the phone, but he's the best resource there for your issues. Tell him I referred you. Please let us know when you work out a solution for your problem. Thanks
5 meter Langford Nahanni
Old 05-26-2008, 10:30 AM   #4
1977 Argosy 24
Scarborough , Maine
Unfortunately no hatches and shut and locked tight. I am up a creek right?
Old 05-26-2008, 10:32 AM   #5
1977 Argosy 24
Scarborough , Maine
Thanks I will give it a try. I just want to get in so badly.
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
Broken Door Latch Ranger 6 Doors & Locks 4 09-24-2009 08:23 PM
Broken Interior Door Latch Handle!!! Boaz1362 Doors & Locks 9 08-19-2009 01:26 PM
Screen door latch broken redeagle313 Doors & Locks 5 04-20-2009 05:03 AM
Broken Door Latch Ranger 6 Doors & Locks 2 12-20-2005 05:55 PM
