Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 02-15-2014, 05:23 PM   #1
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Best way to lubricate door hinge?
I see that some folks have problems with the hinge pin coming out.
Our problem is that lately the hinge is much stiffer.
I know that in the aircraft world, aluminum hinges are lubricated with dry graphite....but how do you get the graphite to travel up and down the pin?
All suggestions would be appreciated.....
Bob and Gail
Bob (K5RPS) and Gail (MAAAA)
31' 1981 Excella II
2001 F-250 7.3D Crew w/8'bed and Pullrite 180degree
"Ask the Man Who Owns One" (Packard, Of Course)
or
"Ask the Woman who lives with one...or more!" (Gail)
ole81 is offline   Reply With Quote
Old 02-15-2014, 05:34 PM   #2
r carl's Avatar
Lin , Ne
Take the pin out and clean and lube it is one option.
Old 02-15-2014, 05:36 PM   #3
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Perhaps use graphite on the locking mechanism, teflon lube or a little 3 in 1 oil on the hinges?
Bob and Nancy
https://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 02-15-2014, 07:18 PM   #4
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Thanks for the prompt responses
My understanding is that the aircraft world recommends against using oil on hinges because oil can carry grit into the hinge and make matters worse.
Unfortunately, the pin cannot be driven out because the base of the fitting is blind....so that the pin cannot fall out the bottom.
Bob and Gail
31' 1981 Excella II
or
Old 02-15-2014, 07:41 PM   #5
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
You might try some Lockease. It's basically graphite in a penetrating liquid. When applied, the liquid evaporates leaving the graphite. You can pick it up at most hardware stores.
AGS Company - Lock-Ease® Graphited Lock Fluid
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 02-15-2014, 07:55 PM   #6
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Many thanks.
I have never heard of that product, but will check the local hardware stores next week.
...and will report my findings...and hopefully success.
Bob and Gail
31' 1981 Excella II
or
Old 02-16-2014, 05:35 AM   #7
dznf0g's Avatar
Oswego , Illinois
There are also a variety of dry lubes made for bicycle and motorcycle chains which penetrate, dry and leave a lube behind. Some are parifin based and some are Teflon based. I like them a lot. Designed to penetrate deep and don't attract dirt nor wash off. They are typically clear and colorless as well.
Sent from my XT907 using Airstream Forums mobile app
-Rich-
Old 02-16-2014, 07:07 AM   #8
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
The dry lubes work very well. I also use them on the folding step. They don't collect grit and last quite a while. I have found them at the big box stores.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 02-16-2014, 08:39 AM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I use Boeshield T-9 to lube and provide corrosion protection to the door and step hinges, stabilizer jacks, as well as corrosion protection for the underbody steel. Leaves a paraffin wax film when it dries.
Doug and Cheryl
Old 02-17-2014, 08:53 AM   #10
knunut's Avatar
2023 16' Basecamp
Chgo. N.W. Burb's , Illinois
I use Boeshield T-9 for hinge and awning hardware. Works Great.
knunut is offline   Reply With Quote
Old 02-21-2014, 01:57 PM   #11
1999 28' Excella
New Orleans , Louisiana
My new problem..seem to have graphite coming out of my top door hinge and the door is not closing as well.
What is the solution? Have an RV guy coming out in a couple of days. What should he look for? HELP! I am a full-timer so need this fixed.
badkat is offline   Reply With Quote
Old 02-21-2014, 03:15 PM   #12
dkottum's Avatar
Here's the Airstream door adjustment procedure if the door is not closing well. It may be the trailer is sitting a bit off level, or a stabilizing jack is too tight, before you start adjusting the door.
Doug and Cheryl
Old 02-21-2014, 03:39 PM   #13
Ottawa , ON
This is one of the things I always use spray silicon on.
It's clean to use, seems to be willing to migrate into the door hinges enough to reduce or kill friction and/or squeaks without making a mess. OK, it may have to be applied more frequently than a graphite-based lube, but the graphite ones I have ever used leak out and stain things, me included.
Another plus is that it is I find the silicon spray to be a good product to put on your rubber door seals, at least twice a season. Keeps them supple, which allows them to make better contact.
Old 02-21-2014, 05:43 PM   #14
1999 28' Excella
Thanks..adjusted the stabilizers and things look good. The video also is very helpful.
Yeah..no repair bill,
How to lubricate breakaway switch? bonginator Brakes & Brake Controllers 14 10-01-2013 08:57 AM
grey water dump valve won't open adonh Sinks, Showers & Toilets 15 04-06-2013 09:46 AM
