Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 04-13-2014, 04:56 PM   #1
1970 31' Sovereign
Apple Valley , California
tv installation
We have a 1972 Ambassador and If you can and if so how can do you fit this vintage trailer with a flat screen TV?
Beverly II is offline   Reply With Quote
Old 04-13-2014, 06:05 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I have modified this a bit since I took the pictures, but this was my solution. Click image for larger version
Name:	ImageUploadedByAirstream Forums1397433848.068987.jpg
ID:	209623Click image for larger version
Name:	ImageUploadedByAirstream Forums1397433891.416656.jpg
Old 04-13-2014, 07:29 PM   #3
1970 31' Sovereign
Thank you so much pictures and all. We also, need advice on the wiring of the TV for antenna, receiver, satellite providers and which products and services are best for your dollar?
Old 04-13-2014, 07:38 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
There is a big thread on satellite services and equipment on this forum, I can't help on the satellite thing as I haven't used satellite in a vehicle in well over a decade.
We get by with a small indoor antenna and a Roku.
Old 04-13-2014, 07:40 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
http://www.airforums.com/forums/showthread.php?t=106283
Here is the forum link.
Old 04-13-2014, 07:53 PM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
We don't have cable or satellite service in our home. We use a Jack Antenna and are able to pull in about 15 channels. We also use a Jack Antenna when camping in the Airstream. See items 20-22 in my thread "Dan's '66 Tradewind Improvements" I mount the Jack on a flagpole. It works fine unless you are deep in the mountains. We have a 21" TV powered with 12v, so no inverter needed, and we also power the Jack Antenna off the 12v power supply. It comes with both a 12v or 120v power supply.
Good Luck, Dan
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
Olympic rivet removal and installation PeterH-350LE Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 09:40 PM
installation of shocks TCP4 Shocks 1 05-02-2002 04:45 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
