Tom, there are at least two versions of the antenna booster. Mine was not documented in the manual. As Dave mentioned, one needs the booster turned off. On my unit, I have to repeatedly push the button until "park cable" LED is illuminated.
You also need to ensure that the TV signal source is set to cable in the TV's menu system.
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
Check the back of the TV. On our 09, there are two separate coax inputs, one for antenna channels and the other for cable.
We have to switch the input cable from the wall between the two depending on the availability of cable tv.
I purchased a "push-on" cable connector to make it easier. No fumbling with trying to thread and tighten the connector in the tight space on the back of the TV.
Regards,
JD
Jeff & Cindy
2012 Interstate Coach
From All Over
, More Than Anywhere Else
After making sure your coax cable input is to the jack marked "cable" on the back of the TV, and that "cable" is selected from your setup menu, you may also have to do a channel scan, just as you do with the antenna, so your TV knows which cable channels are available.
