Old 01-22-2017, 12:05 PM   #81
2019 27' Globetrotter
Salem , Oregon
Trouble with BMV-702
After leaving my trailer plugged in for the past month I went out to see the state of charge using the MBV-702 and discovered a blank display.
I checked the connecting cable and re inserted the cable from the shunt and the monitor.
I don't know if the monitor or the shunt is bad? Any idea where to check next. I would like to do all my homework before I contact the seller.
Again it has been working but just went dead.
Thanks, Dave
NoResults is offline   Reply With Quote
Old 01-23-2017, 09:39 AM   #82
2016 28' International
Redmond , Washington
Dave, power would be my first guess. I'd do the following:
1) Remove and insert the wire ferrel that goes from the positive side of the battery into the shunt, sometimes they don't seat right.
2) Check your batteries aren't dead using a volt meter, also check the voltage using one probe on positive side of battery and negative probe one each end of shunt.
3) Check the continuity between the positive wire from your battery to the shunt.
4) Grab an off the shelf phone cable (make sure all 6 conductors are wired up) and try that.
There's a also a trouble shooting section in the manual - https://www.victronenergy.com/upload...S-SE-PT-IT.pdf
Mgieselman is offline   Reply With Quote
Old 01-23-2017, 10:02 AM   #83
Salem , Oregon
Thank you mgieselman. My trailer had been hooked to shore power for some time. I disconnected from the house and let it sit and it now works again.
Apparently it does not like to have constant current from the charger although I have the PD 4655 smart charger.
Hopes this helps other than may encounter problems.
Dave
Victron Battery Monitor with Bluetooth connection to smart phone jhart657 Electrical - Systems, Generators, Batteries & Solar 23 07-27-2016 01:56 PM
Battery Monitor versus Inverter Install Questions Searun Batteries, Univolts, Converters & Inverters 4 05-24-2016 01:34 PM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
