Closed Thread
Old 12-09-2009, 05:08 PM   #21
2xS
2xS's Avatar
1971 31' Sovereign
San Diego , California
what a great post... and then I forgot the attachment...
Name:	71 interior 12V system.JPG
Lasciate ogne speranza, voi ch'intrate
2xS is offline
Old 12-09-2009, 06:45 PM   #22
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
WOW......REALLY WOW.... 2Xs That is amazing
Thank You ~ Cynthia
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline
Old 12-09-2009, 07:33 PM   #23
2xS
2xS's Avatar
1971 31' Sovereign
Thanks Cynthia!
Hope you'll be able to get your system off to a good start!
When it comes down to it:
the blue box (univolt) = a battery charger + a fuse block
Cheers!
~Dennis
2xS is offline
Old 12-09-2009, 08:01 PM   #24
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Thank You ~ Cynthia
I agree 100%. Impressive work Dennis.
In her case, absolutely. In the case of one like mine:
the blue box (univolt) = a battery charger - a fuse block (external fuse block)
That's why I kept hedging my answers. The only reason I could see for any of the blue box to remain was for the fuse block, but I didn't know for sure how Cynthia's trailer was built. Wasn't sure how things were done in 71. Thanks for clearing things up.
Vaughan
vswingfield is offline
Old 12-09-2009, 08:25 PM   #25
Ottawa , ON
2xs,
That is one heck of a rig that you are using to replace your fusebox and Univolt!
I'm guessing, due to its shape, that this will go across the front of the trailer. Have you done any calculations on what the impact on your tongue weight will be, once all 6 batteries are loaded?
Also, do you plan to ensure that the Arc is isolated from the trailer's air space? I believe that there is a safety reason for making sure that such is the case. You probably noticed that the original battery space was only open to the outside, and not the trailer's interior.
Perhaps the fans are designed to vent to the outdoors?
Aage is offline
Old 12-09-2009, 09:15 PM   #26
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
aage, was planning to move my battery to under he curbside twin instead of putting it back in the rear. Is this a Bad Idea??
Old 12-09-2009, 09:28 PM   #27
1983 34' Excella
1967 24' Tradewind
Images: 32
You will want to ensure that the battery cannot vent gases (hydrogen mostly) into the interior. Some have installed sealed AGM batteries without doing this, but my understanding is that this doesn't technically meet code. I haven't switched to AGMs and have no immediate plans to do so.
I can tell you that an improperly vented battery being boiled by a faulty Univolt will set off a carbon monoxide detector. Very unsettling in the middle of the night.
Vaughan
Old 12-09-2009, 09:37 PM   #28
Retired.
. , At Large
And it doesn't smell very good, either ...
Just today I replaced a bad Univolt with a modern converter. I pulled apart the old Univolt, salvaged the fuse panel, heaved the rest of the boat-anchor-formerly-known-as-a-Univolt out the door, and built a small electrical center out of the upgraded converter and fuse panel.
At least yours is out in the open, I had to tear apart a closet and dig under the bathtub to get at the one I replaced.
overlander63 is offline
Old 12-09-2009, 09:47 PM   #29
Ottawa , ON
Yep, I'm afraid it is. Greater minds than mine can tell you exactly why, but it seems certain that it's not advisable.
Aage is offline
Old 12-09-2009, 09:55 PM   #30
Ottawa , ON
Terry, that's my problem exactly. I have the new converter, and I even bought a new distribution panel (fuse panel) but when I went to sketch out a plan to do the swap, I looked into the current Univolt's home there, in the corner of the closet, and I could NOT imagine how my big hands would be able to manoever in there to undo all the bolts.
I had a nightmare-type flash that I would be forced to remove the tub.
I asked when I was at JC, and they (half-jokingly, I thought) suggested that I get a 7-year old to do it for me.
On mine (and probably on yours too) there is a U-shaped metal cover over the Univolt, making the access to the rear bolts look impossible for an adult hand.
Any hints? Oh, just re-read your description, and you took out the closet wall adjacent to the tub, is that right?
Aage is offline
Old 12-09-2009, 10:11 PM   #31
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
It's never as simple as a yes or a no on most any subject.
http://www.airforums.com/forums/f449...box-58059.html
http://www.airforums.com/forums/f449...ery-40049.html
On both my Airstreams I have batteries that live inside. I have updated converters and have sealed batteries. Even with sealed batteries vent tubes are suggested. Do your research.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline
Old 12-09-2009, 11:05 PM   #32
2xS
2xS's Avatar
1971 31' Sovereign
The ARC actually weighs less than the Univolt!!! But seriously, each battery alone is about 50lbs. x 6, and the rest of it combined (including framework) is probably about 100lbs-125lbs. So the whole thing total is about 400lbs. What can I say? Electricity is mandatory, after all, I hold a BS in Electrical Engineering.
The ARC is installed in the forward portion of the trailer.
The ventilation system utilizes air from inside the trailer, and it only kicks on when the temperature inside reaches my desired set point. I suppose I could route it out, but at the moment, I'm trying to keep in any warm air I got inside. Several detectors are used to ensure I'm not dying for my electricity.
And as long as you insulate the terminals on the battery, and you have an AGM battery; it shouldn't matter where you put it. The only concern is if your battery charger overcharges the battery as this is what causes hydrogen pockets; in other words, get a microcontroller based charging system to help eliminate that possibility. But planning an enclosure with ventilation to the outside is probably the safest idea... There are several options for an outside vent if you'd like to place it under the twin: 1) the trunk space in that same area, or 2) you could tap the air vents for the drains; one will be accessible under your kitchen counter behind the sink, and another would be in the passenger closet.
And Aage... you know that tub has to go anyways
ID:	92357   Click image for larger version
ID:	92359   Click image for larger version
2xS is offline
Old 12-10-2009, 06:08 AM   #33
"Cloudsplitter"
My experience only....I may just wait 'til a problem shows it's ugly little face before replacing full speed ahead...
http://www.airforums.com/forums/f449...ems-55549.html
ROBERT CROSS is offline
Old 12-10-2009, 06:25 AM   #34
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Wow,
Dennis has a serious boondocking setup....just add a solar panel or two.......
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
--Mark Twain
Alwhisman is offline
Old 12-10-2009, 09:21 AM   #35
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
ahead...
AMEN... Then the rear floor rot rears its UGLY head
Old 12-10-2009, 09:24 AM   #36
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Diggin your tub replacement. Where did you get the pan? Did you need to reroute the drain? Is the top braced as a seat? Lookin good!
Old 12-10-2009, 11:33 AM   #37
2xS
2xS's Avatar
1971 31' Sovereign
Boondockin' someday... today I get to pull out a bad furnace... BBBBBBBRRRRRRRRRR
I replaced the tub with a 32"x32" shower pan. It was the largest size I could get to fit in the space. I got the pan at Lowes; I believe it was about $120. No special order: it was just there on the shelf. Then I got to rebuild the counter and all that; yay! The tile bathroom counter does double as a seat; I made sure of that with some 90 degree brackets, rivets, and a whole lotta support structure.
I did need to reroute the drain; the tub was like 22"x44" and its' drain was in the middle closer to the edge by the door. My pan had the drain dead center. It wasn't too far off though. I had to cut away a little more of the floor there in order to make it happen. I managed to be able to tap the existing drain line and with a couple fancy ABS angles and some luck trying to set the pan on the fitting and in the spot. It wan't easy, but knowing I won't have to sit down to shower (in a tub that was disintegrating) makes all the effort well worth it.
ID:	92379   Click image for larger version
2xS is offline
Old 12-10-2009, 11:36 AM   #38
2xS
2xS's Avatar
1971 31' Sovereign
Thanks!
I think I'm going to try my hand with a wind turbine though. I found a $450 unit that pulls 400W. Solar just can't do that....
Amazon.com: Sunforce 44444 12-Volt 400-Watt Wind Generator: Automotive
2xS is offline
Old 12-10-2009, 01:05 PM   #39
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
PRICELESS!!
Thanks for the photos...
Im very visual and this too is PRICELESS
Cynthia
Old 12-10-2009, 01:10 PM   #40
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Oh yeah, what material did you wrap the pan with? The sheet vinyl?
How about the counter/seat the tiles? Are they on a hardi backer type material or just glued down on subtop?
Closed Thread
Electrical Upgrade rc707 Electrical - Systems, Generators, Batteries & Solar 15 05-31-2008 08:17 PM
A little lighting upgrade thecatsandi Lights - Interior & Exterior 19 11-22-2007 08:28 AM
Lighting upgrade mkeith54 Electrical - Systems, Generators, Batteries & Solar 1 06-20-2005 08:00 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
