05-21-2007, 01:04 PM
1993 34' Excella
Estancia
, New Mexico
Univolt/ battery/ shore power question
Until yesterday both by 110 and 12v were fine. Today the 12v system works only when connected to shore power and does not work at all when not connected to shore power. The battery voltage is 12.89v If I disconnect the battery the leads show no voltage coming in. The control panel battery meter reads 0 when the shore power is off. I replaced 1 12v burned out fuse but it doesn't make any difference. Any ideas what I should check, or is this 35 year old univolt finally toasted?
05-21-2007, 01:18 PM
1966 22' Safari
1979 30' Argosy
Armada
, Michigan
It's not your univolt, probably. You would still be getting 12 vdc power. Likely there's more fuses blown. If you haven't done so, get and replace all of your fuses in you panel. Also, check you fuses by or in the Univolt for blown fuses. Also, look for a disconnect in the ground somewhere, that would possibly create the situation you are describing.
05-21-2007, 04:00 PM
1978 31' Excella 500
Venice
Here's the logic:
1) If you have 12vdc on shore power, the circuitry and the univolt are OK.
2) Since the battery shows voltage, there must be a disconnect between where the battey(s) hook up and where the univolt hooks in. Look carefully at the battery terminals and where the battery cables go to ground and to the positive buss in the control panel
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
05-21-2007, 06:11 PM
1984 31' Airstream310
Dunsmuir
I'd suggest that you put the positive probe on your meter on the Positive (+ Red), post of your battery, then touch the negative (- black) probe of the meter to the chassis of your coach. If you don't get essentially the same voltage as when you put both probes on the battery, you have a ground problem.
1984 310 Limited Motorhome
05-21-2007, 07:01 PM
1993 34' Excella
Estancia
, New Mexico
Found the varmint, I think
The fuse that was burned out that I mentioned earlier was the one for the car battery connection it was supposed to be 40 amps, the PO put in only 20. do you think that had something to do with it blowing? Really?
But I think the real varmint was the 40 amp fuse for the coach battery. I took out all the fuses and VISUALLY inspected them. It looked OK so I put it back............... I just tested it and it has no continuity, duhhhh.
Thanks for the other answers. Got me going in the right direction this time. And some helpful hints.
The acid test is when the parts store opens and I get another fuse.
05-21-2007, 07:33 PM
New Borockton
, Alabama
Those fuses are probably AGU and getting harder to find in 40 and 50 amp but they are out there. I never see them in hardware stores or auto parts stores any more but maybe you will get lucky at an RV parts store. Many of them stock them. If you can't find them, let me know and I'll send you a couple for just the postage.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
05-21-2007, 08:10 PM
1993 34' Excella
Estancia
, New Mexico
I had a sneaking suspicion about that I will check with my next door neighbor the town auto parts store, but I think I will not find them locally. I'll let you know tomorrow.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
battery charger
ALANSD |
Batteries, Univolts, Converters & Inverters |
8 |
09-16-2007 05:52 PM |
Univolt FACTS
smily |
Electrical - Systems, Generators, Batteries & Solar |
69 |
08-18-2005 11:47 PM |
Second Battery
w9det |
1997 - 1999 Safari |
5 |
12-06-2002 06:42 PM |
Battery drained while on shore power
68International |
4 |
07-15-2002 02:51 PM |
Electrical System Question
ViewRVs |
Mechanics Corner - Engines, Transmission & More... |
2 |
03-16-2002 07:39 PM |
